Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: ARSone24's Yeti
Old 10-21-2015, 08:51 PM   #1
Default ARSone24's Yeti
Well I figure my Yeti is descent enough to post now. It has most of the standard mods. Hopefully by the end of the year ill have the HH540xl with an MMP Im just waiting for a xmas sale or something.
The front end consists of RPM arms cheap Ebay aluminum castor blocks and shock tower with GPM tie rods. I just installed a full Blue monkey cvd MIP setup which required shaving of the RPM arms. Still thinking about which way I want to go to mount the shocks. The rear consists of MIP rear shaft. SSD rear axle and lower arms. Vanquish upper trailing arms and the SSD 2spd. Probably leaving some stuff out. On to the pics! The last pic is the current state with all the panels.
ARSone24 is offline   Reply With Quote
Old 10-22-2015, 05:51 AM   #2
Default Re: ARSone24's Yeti
Nice Yeti, looks to be a pretty much bullet proof drive train. Should handle the puller pro xl no problem.
CamaroTom is offline   Reply With Quote
Old 10-22-2015, 11:09 AM   #3
Thanks its getting there, def no where near some of you guys. I still have to think about wheels after the motor upgrade.
Old 10-25-2015, 01:34 AM   #4
Hi
I have the same blue monkey thing in front ! Do you have some pics after finished mounting?
Thanks mike
Gesendet von iPad mit Tapatalk
mthrams is offline   Reply With Quote
Old 10-25-2015, 01:38 PM   #5
Yes. If your wondering, there's a lot of grinding of the rpm arms and you have to mount the shock in front of the arms.
Old 10-26-2015, 03:08 PM   #6
Thanks for your pics! I am still building!:-) how is the performance from your shock after mount in front of the arms? Same good like before? You have stock springs? What kind of oil are you using?
Thanks mike
Gesendet von iPhone mit Tapatalk
Old 10-26-2015, 05:46 PM   #7
Thanks mike
Im still dialing it in, the spring are the super firm blue springs. Haven't had a chance to take it to the trails yet but it def. crawls up things better.
Old 11-11-2015, 05:23 PM   #8
So I've decided to bite the bullet and this came in. I can't wait to see how it performs.
Old 11-20-2015, 06:38 AM   #9
Looking sharp! What body panels and roof rack did you go with?
Davey is offline   Reply With Quote
Old 11-20-2015, 09:04 PM   #10
The side panels are carter fab, the roof and hood are from AMF racing bought on EBay and the rack is a gear head from RPP. Also got the new electronics installed!! Still haven't driven yet, family duties come first.
Old 11-23-2015, 08:16 AM   #11
How are the gpm turnbuckles holding up? I was eyeing those for my yeti
totallypro is offline   Reply With Quote
Old 11-23-2015, 05:40 PM   #12
good so far can't complain. Very solid feel and the plastic rod ends are firm.
ARSone24's Yeti - Similar Threads
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti FastEddy Axial Yeti 13 04-21-2015 07:33 AM
