11-03-2015, 06:21 PM | #1 |
I wanna be Dave Join Date: Sep 2004
| dlux modded axle housing question
do i shim the gears? i remember reading that the mesh will be tight when new and break in upon use. i assume i dont shim it then? thanks. |
11-03-2015, 10:03 PM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
| Re: dlux modded axle housing question
Mine didn't need any shims. FI locker with 43/13 gears.
11-04-2015, 05:13 AM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I guess if you need to, mine was perfect when it arrived for sure.
11-04-2015, 06:39 AM | #4 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Didn't shim mine and also using FI spool but 38/18 HD gears. No issues so far.
11-04-2015, 08:16 AM | #5 |
Pebble Pounder Join Date: Dec 2013 Location: Derby Line
Eric from D-Lux has made a really good job figuring the position on the new bearing so you will most likely not need to shim. In the yeti I built for a friend, after a while, the HD gears broked in, I added a little shim. All D-Lux I used didn't need any shimming with new HD gears ( yeti or wraith) from the start. Theses axle combine with Beeftube bullet proof the drive traive quite a lot. I don't built anything without these!!! Good work Eric, since Axial don't seem to realize the abuse we give to these rigs!!! Last edited by Breat 1.8T syncro; 11-04-2015 at 08:18 AM. Reason: correct mistakes! |
11-04-2015, 08:20 AM | #6 |
I agree with the above statement. Dlux housing, Beef Tubes, Dlux G10 Truss, and your flavor of aluminum lockouts....no way you're breaking the axle! I need aluminum housings...likely the VP clamping ones...simply because one of my stock plastic ones has a stripped screw hole on top, which prevents the truss from holding in place. Can't exactly loc-tite into plastic.
11-04-2015, 10:58 AM | #7 |
I run my wrexo with D-Lux modify housing, beeftube, and SSD wide lock out and if you put Loctite in the beeftube threaded holes, they don't come loose. I use Permatex gel thread and since it doesn't dry hard like the liquid Loctite, the lockout don't come loose. And I pound on the Wrexo pretty bad!!! |
11-04-2015, 05:13 PM | #8 |
thanks guys, i have everything stated above. this should be bullet proof now. i have the strc aluminum lock outs and they do come loose. they wiggly on the axle housing. im thinking of putting a little shoe go on the splines??
11-05-2015, 06:28 AM | #9 |
| Re: dlux modded axle housing question I've heard of people having issues with the STRC lockouts, which is why I'm going with the VP clamping ones. Everything else on my rig is STRC, but I didn't wanna chance it on the axle.
11-05-2015, 04:26 PM | #10 |
| Re: dlux modded axle housing question |
11-06-2015, 05:29 AM | #11 |
Wiggly was something VP used to have on their aluminum housing to their VP lockouts, I think they fixed this in later chubs. Even perfectly threaded and tight screws there was always a tough of the wiggles and would wiggle more and more. I used tin foil on the splines to tighten up the fit, worked great. |
dlux modded axle housing question - Similar Threads | ||||
Dlux links on modded LNC - driveshaft issue | motopreserve | Team Losi Comp Crawler | 6 | 10-25-2014 10:41 AM |
***REVIEW*** DLUX Fab 70* XR10 modded steering shafts | chicklet | Axial XR10 | 6 | 07-10-2013 01:18 PM |
Using a front axle housing on your rear axle | nstn8 | Axial XR10 | 2 | 10-25-2011 07:32 AM |
