Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Upgrade Gearing for front and rear diffs
Old 11-17-2015, 08:34 PM   #1
Default Upgrade Gearing for front and rear diffs
Was wondering if someone could help me, wanted to upgrade the front and rear diffs with the HD gears, but what tooth count would get me more speed. The 36/14 or the 43/13, thanks in advance
mbztech88 is offline   Reply With Quote
Old 11-17-2015, 09:09 PM   #2
Default Re: Upgrade Gearing for front and rear diffs
36/14 is overdrive, 44/13 is underdrive.
Overdrive has a higher ratio, but the worst gear mesh.
gbean is offline   Reply With Quote
Old 11-18-2015, 08:36 AM   #3
43/13 will slow you down, but should hold up longer. It's what I'm running in my 4S Yeti. To compensate I went with optional high ratio in my 2 speed and stepped up to a 17t pinion. Right now I'm running around 35mph top speed.
CamaroTom is offline   Reply With Quote
Upgrade Gearing for front and rear diffs - Similar Threads
going to order ceramic boca bearings for front and rear diffs ... which ones? mushroom281 Axial Yeti XL 2 03-11-2015 07:08 PM
glue the front and rear diffs ? cricco Losi Mini-Rock Crawler 5 11-03-2009 02:16 AM
Front and Rear Gearing Neil E Newbie General 13 01-01-2008 10:18 PM
am I suppose to lock my front diffs on mey e-maxx bulletproofcustoms General Crawlers 3 06-21-2004 02:55 PM
