12-10-2015, 08:37 PM | #1 |
Pebble Pounder Join Date: Aug 2015 Location: Red Hill, PA
| Cat's SCORE Truck Build
Got this truck last week and I am already to think up plans for it. I am planning on trying a somewhat scale build (scale to what, I don't know ). The caveat is that this will be a basher, trail runner, and even a light crawler. I will try to make it as detailed as possible without sacrificing function or my willingness to bash on it. After watching the Redbull Signature Series winter rush I decided I wanted flaps all the way around. Not only because I like the look but also to keep the truck a bit cleaner. Materials Used (all from McMaster Carr): 1. 1/16"T by 1/4"W brass bar 2. Neoprene Rubber #8568K18 Durometer 30A (soft) sheet 3. M3 x 10L machine bolt SS 4. M3 Flat Washer SS 5. M3 Nylon Locking Nut SS More to come as parts arrive (AKA When I can afford them ) Last edited by Arctic Cat ZRT; 12-10-2015 at 08:46 PM. |
12-10-2015, 08:40 PM | #2 |
Quarry Creeper Join Date: Apr 2013 Location: perkasie
| Re: Cat's SCORE Truck Build
Cool!......i may steel this idea for this truck and my landys......where did you get the rubber material for the flaps?
12-10-2015, 08:45 PM | #3 |
| Re: Cat's SCORE Truck Build All of the materials are up on the thread before the pics. Got it from McMaster Carr through my work. The part number at McMaster is 8568K18 must specify hardness, I chose 30A (soft)
12-10-2015, 09:48 PM | #4 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Very nice! Now just wait after few months of beating on your rig you look and say "wait...... Did someone steal one of my mudflaps?"
12-11-2015, 10:04 PM | #5 |
Welp today I got some parts in the mail from RPP. Big thing was the 20T 32 pitch pinion gear which worked out great and definitely woke up the truck! Still have plenty of power down low but now has some more speed. Thats even when I had only a somewhat dead pack to test with for a few mins. Other things added include the gear head 6.5 light bar and gear head 3 way splitter with 4 AAA battery supply for the lights. I still want to try to run the wires a bit cleaner. Reason I chose the separate light option was due to the face I didn't want to fumble with connectors each time I wanted to take the body off. I did though connect the battery box using heavy velco, I'll be interested to see how that holds up. I'll end up ripping the LEDs from the back buckets once I get one of gear head's rear LED bar. Issue with both front and back buckets is that they fog up easily and get dirty/mud in them. Actually taped over the fronts with black electrical tape from the inside already. I will probably paint it over the clear areas black once I get around to it. |
12-13-2015, 06:33 PM | #6 |
Sorry for the double post. Update 12/13 Truck speed was greatly improved with 20 tooth pinion. I did notice after going though a half battery pack at the track that my motor temps were up a considerable amount from my first run on the 16 tooth pinion. I could touch the motor without burning myself but any hotter and I couldn't. Track was at the LHS so I ran in and got a dual fan Integy motor cooler, believe it originally is for a 4x4 slash. Popped right on and brought my temps down to around 70-80 degrees. Keep this in mind if you up the tooth count! Does anyone have any suggestions on how to mount the cooler better than some zip ties? I also noticed that my body has started to crack around the cage mount, will be picking up some drywall tape and some more shoe goo tomorrow. |
02-17-2016, 09:03 PM | #7 |
Update 2/17/2016 SSD 10 hole beadlocks black Front: Vanquish .225 Hubs + narrow axial hexes Rear: Vanquish .350 Hubs + standard axial hexes Axial Score Clear Body (RTR replacement) Lights still need to be placed on the truck On Order: Hot Racing 2 speed and 18 tooth pinion (dropped from 20t due to increased tire size and higher second gear in trans) |
02-17-2016, 09:19 PM | #8 |
Pebble Pounder Join Date: Dec 2012 Location: The fun house
Glad to see my hub set up worked for you
02-18-2016, 07:09 AM | #9 |
| Re: Cat's SCORE Truck Build Appreciate the help and advice on your experience. With the rear setup the track is about the same as stock but on the front even with the narrow hexes it is a bit wider. Thus I have to trim out the wheel wells in the front. Decided to do the rear as well so it looked good. Thanks again! |
02-18-2016, 08:34 AM | #10 |
Pebble Pounder Join Date: Oct 2011 Location: SLC
I have really been looking at the hot racing 2 speed. I'm interested to see how you like it
02-20-2016, 06:16 AM | #11 | |
| Re: Cat's SCORE Truck Build Quote:
Before I did this mod I had installed a VP front shock adjuster, which limits upward travel, so the body does not hit, but again limits travel. I read someone flipped the shock adjuster, I am going to try that and see how much its hits. | |
02-20-2016, 03:09 PM | #12 |
Got the body and lights on! Also hooked up the Hot Racing 2 Speed. Didn't have any directions so it made the install interesting. Also had some trouble with the shift servo the way the linkage is set up. Had to do some monkeying to get it right. The low speed is extremely low, which I like! If you have another questions about it let me know! Trail run is tomorrow morning! |
Cat's SCORE Truck Build - Similar Threads | ||||
Cat's "Gravity" Build | Arctic Cat ZRT | Axial Wraith | 18 | 11-21-2015 11:05 PM |
JPRC Unboxes the Score Trophy Truck | joerc2013 | Axial Yeti | 4 | 11-19-2015 11:44 PM |
JPRC Redbull Trophy Truck VS Score Trophy Truck STRC Upgrade | joerc2013 | Axial Yeti | 10 | 11-13-2015 11:06 AM |
SCORE trophy truck crawler | 4RnrRick | Tamiya TLT Crawlers | 34 | 06-05-2008 11:26 AM |
