02-26-2016, 11:11 AM | #1 |
Pebble Pounder Join Date: Feb 2016 Location: canandaigua
| Overdrive
So I ordered the overdrive HD bevel gears for my yeti 1/10....here's the issue if I run them up front with stock gears in the rear diff what will happen? Do I Need To Go Full over/under I Want Speed But I Want It To Be able To Handle Large Obstacles Any I'm put Would Help thanx Sent from my SM-G900T using Tapatalk |
02-26-2016, 11:16 AM | #2 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: Overdrive
Over/stock in a fast vehicle will put an enormous strain on the drivetrain. If you aren't snapping driveshafts, then the back end will be hopping all over the place at speed.
02-26-2016, 11:20 AM | #3 |
| Re: Overdrive
So over/under is my best option? Or just leave it stock Sent from my SM-G900T using Tapatalk |
02-26-2016, 11:24 AM | #4 |
Quarry Creeper Join Date: Nov 2014 Location: WA
| Re: Overdrive
If you want to go fast just keep stock/stock (maybe under/under or over/over) and play with the spur/pinion instead. specially if you drive in high grip terrain. Over/under is great if you want to crawl/hill climb and kinda go slow and low grip surfaces. |
02-26-2016, 11:36 AM | #5 |
| Re: Overdrive
So for trail running and bashing keep it stock? Sent from my SM-G900T using Tapatalk |
02-26-2016, 01:06 PM | #6 |
| Re: Overdrive
stock or under/under.
02-26-2016, 04:19 PM | #7 |
Quarry Creeper Join Date: Nov 2007 Location: WNC
| Re: Overdrive
Under/Under!!
02-26-2016, 04:37 PM | #8 |
| Re: Overdrive
Y under/under Sent from my SM-G900T using Tapatalk |
02-28-2016, 11:02 AM | #9 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
| Re: Overdrive
I went underdrive front and rear. Supposedly, this ratio yields the best mesh. I feel the stock gearing is already bordering on being too tall for the Vanguard system. Extended high speed runs, the motor gets super hot. Any low speed crawling and the esc quickly rises in temp. Besides the better mesh and lowering temps slightly, the UD gears also give the added benefit of less torque twist. I run OD/HD in my scx10 and HD/UD (f/r) in my wraith. But it definitely puts a drag in the drivetrain. As others have said, I wouldnt recommend it in the yeti. Use the same ratio front and rear, whatever you choose. |
02-28-2016, 11:54 AM | #10 |
| Re: Overdrive
Anyone have any problems fitting the overdrive gear in the front diff case?
03-01-2016, 07:41 AM | #11 | |
| Re: Overdrive Quote:
There shouldn't be any problem. I had zero issues fitting the HD Underdrive gears and Axial locker in the front of mine. One thing, you might want to remove the front skid plate unless you want to pry the assembly into the case. | |
03-01-2016, 08:09 AM | #12 | |
I joined the Band! Join Date: Feb 2015 Location: On a rock
I run over/under, on a 3500kv HH Puller motor, And can run full open throttle and never even notice the ass end being dragged, let alone hopping lol. Now. When running on a sidehill, The ass end going slower can have a tendency to want to pull the ass of the truck down the hill. Just a smidge of driving adjustment can clear that up however.. The perks so far have far outweighed any perceived con. | |
03-01-2016, 08:53 AM | #13 |
| Re: Overdrive Thanks, I hadn't heard of the problem before. But my front OD gear literally touch the front diff case in several places not by much but enough to give it a rough feel. I'm running the Dlux big bearing mod as do many. I'm starting to wonder if I got a out of spec counterfeit 43/13 gear set?
Overdrive - Similar Threads | ||||
How much to overdrive? | TurboShadow | General Crawlers | 2 | 05-31-2011 08:24 PM |
overdrive gears | crawler pilot | Losi Mini-Rock Crawler | 13 | 11-29-2009 04:23 PM |
Overdrive? | BJoe | General Crawlers | 0 | 10-31-2009 10:10 PM |
