04-03-2016, 12:42 PM | #1 |
Quarry Creeper Join Date: May 2014 Location: United States
| stongest hinge pins?
what are the strongest hinge pins for the yeti front lowera arms? ive heard of some people using drill blanks but im not sure those would be that strong.. what sre you guys running? i cant get one run in before mine are bent |
04-03-2016, 01:34 PM | #2 |
Newbie Join Date: Mar 2016 Location: USA
| Re: stongest hinge pins?
I use stock pins with RPM arms and a Vanquish skid plate. The trick is to drill out the A-arm pivot points with a 3/16" bit and cut to fit some 316 stainless tubing to encapsulate the hinge pin. I tried to buy the Strong Arm modified arms, but he's not selling any at the present time. I went from bending both hinge pins every bash session to not bending them at all. If you want, I'll send you the Amazon link for the stainless tubing. |
04-03-2016, 02:54 PM | #3 |
could you post the link here so anyone who needs it will see it too? thank you
04-03-2016, 03:27 PM | #4 |
Rock Crawler Join Date: Feb 2012 Location: OC
PM me I have some...
04-03-2016, 03:48 PM | #5 |
You can make 3 sets with one 12" tube. https://www.amazon.com/gp/aw/d/B004X...?ie=UTF8&psc=1 If I bend my current stock hinge pins, I'm going to experiment with heat treating. Last edited by Iwouldntknow; 04-03-2016 at 03:53 PM. |
04-03-2016, 03:49 PM | #6 |
I wanna be Dave Join Date: Dec 2006 Location: here
Home depot sell 3mm bolts that work just fine and cheap.
04-03-2016, 04:51 PM | #7 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
For my outers, I use Lunsford ti pins for the slash. For the inners, I use these: McMaster-Carr Theyre stronger than stock but Ive still bent a couple. But who cares? I have a whole bag of spares. |
04-03-2016, 05:09 PM | #8 |
Rock Stacker Join Date: May 2015 Location: Saint Louis, MO
I use these Carter Fab & Machine » Axial Yeti Hinge Pin Upgrade Kit which I think is just the above linked bolts from McMaster-Carr. FWIW I think anything you use will get bent until you upgrade the lower front bulkhead to an aluminum piece. |
04-03-2016, 06:21 PM | #9 | |
| Re: stongest hinge pins? Quote:
04-03-2016, 09:18 PM | #10 | |
I swapped out the stock skid plate since the journals were wallowed out from the pins, and even more so from constantly removing the bent pieces of old pins. Newest build. The test mule. Multiple 3s bash sessions filled with plenty of ridiculous abuse. No ill effects (save for some broken knuckles, a dogbone, and a rear wheel. Last edited by Iwouldntknow; 04-03-2016 at 09:25 PM. | |
04-05-2016, 07:02 PM | #11 |
thanks for all the replies |
04-27-2016, 04:07 PM | #12 |
Newbie Join Date: Oct 2015 Location: Norwalk, CA
I made my own upgraded arm too with the stainless steel sleeve and added the carter fabrication hinge pin. Best upgrade for the front suspension. I hit my mailbox pole at full speed broke my servo. When I removed the hinge pin, straight and undamaged Made a few extra arms for few friends and they were happy. |
04-27-2016, 05:27 PM | #13 |
Rock Crawler Join Date: Mar 2016 Location: HB
I just did this mod with the stock control arm. Noticed the arm can move front to back. Should I have cut the tube longer? Never noticed this movement before. Sent from my HTC6500LVW using Tapatalk |
04-27-2016, 05:29 PM | #14 |
| Re: stongest hinge pins? Sent from my HTC6500LVW using Tapatalk |
04-27-2016, 05:58 PM | #15 |
I would make it a bit longer, that's to much play
04-27-2016, 06:01 PM | #16 |
That's what I was thinking. Thx
04-27-2016, 07:35 PM | #17 |
Quarry Creeper Join Date: Dec 2014 Location: Sacramento
| Re: stongest hinge pins? |
04-27-2016, 08:23 PM | #18 |
I want to upgrade to the rpm arms and better pins, this is just temporary to get me going. Figured it's a quick and easy mod in the meantime. Cut longer 3/16 sleeves and it took the slop out for now. Should get me through a few bashing sessions.lol
04-27-2016, 09:36 PM | #19 | |
| Re: stongest hinge pins? Quote: | |
05-01-2016, 09:20 AM | #20 |
Rock Stacker Join Date: May 2015 Location: central PA
The debate, of what to use in place of the stock hinges pins, has been going on since the platform was out. I'm not sold on the whole "beefing up" the inner hinge pins on the Yeti. I look at it like... when someone trying to use aluminum arms. In a bad high speed/weird landing situation, and the energy possibly being transferred to a more expensive part to be replaced. IMO I'd rather keep on hand something that costs a few cents to replace.
stongest hinge pins? - Similar Threads | ||||
Hinge pins | Mitchell72 | Axial Yeti | 14 | 04-26-2015 06:08 PM |
Keeping inner hinge pins...? | Sc91gt | Axial Yeti | 6 | 02-27-2015 12:55 PM |
front hinge pins | sally1800 | Axial Yeti | 25 | 10-27-2014 06:45 PM |
Yeti hinge pins | CKRC Hobbies | CKRC Hobbies | 0 | 10-16-2014 05:05 PM |
