06-14-2016, 08:17 PM | #1 |
Rock Crawler Join Date: May 2012 Location: Upland
| Need help identifying parts on yeti I picked up
I traded my wraith for this yeti today and I don't know what most of these aluminum parts are. The hub carriers are the only product that is marked and they are STRC. Also, the top of the servo saver is stripped in the steering. What needs to be replaced to fix it? Any help is appreciated. It's dirty and needs some love. Please. And it looks like stock motor and esc. Is that the stock servo? Sent from my SM-G900T using Tapatalk |
06-14-2016, 08:22 PM | #2 |
| Re: Need help identifying parts on yeti I picked up
Oh wow it's got this huge metal spur gear in it, too The gear mesh has no play. Are these 3mm caps that hold the motor down? Sent from my SM-G900T using Tapatalk |
06-14-2016, 08:48 PM | #3 |
Newbie Join Date: Dec 2015 Location: Canada
Looks like you have gpm lower rear links.
06-14-2016, 08:59 PM | #4 |
| Re: Need help identifying parts on yeti I picked up |
06-14-2016, 09:00 PM | #5 |
Rock Crawler Join Date: Mar 2016 Location: HB
Stock motor and esc yes. Not the stock servo. If the servo saver is stripped I recommend you replace it with the upgraded dual sheer posts, VP or STRC. Wait, where am I? |
06-14-2016, 09:11 PM | #6 |
06-14-2016, 09:37 PM | #7 | |
| Re: Need help identifying parts on yeti I picked up Quote:
Sent from my SM-G900T using Tapatalk Last edited by z50king; 06-15-2016 at 01:41 AM. | |
06-14-2016, 11:19 PM | #8 |
06-15-2016, 03:14 AM | #9 |
RCC Addict Join Date: Oct 2014 Location: UK
06-15-2016, 08:33 AM | #10 |
There's quite a few options depending on what you would like to spend. Steer clear of anything that has the brass ball retainers.
06-15-2016, 09:46 AM | #11 |
The double sheer post doesn't replace the servo saver. The post is what the saver mounts to. Guess I assumed that was what is stripped out. If it's the little screws that hold the saver together you may need to get a new saver. I bought the strc steering assembly because it came with everything but the posts, which I ordered also.
06-15-2016, 10:46 AM | #12 | |||
| Re: Need help identifying parts on yeti I picked up Quote: Quote:
Sent from my SM-G900T using Tapatalk | |||
06-15-2016, 10:51 AM | #13 |
Most of the high end rear links have replaceable rod ends.
06-15-2016, 03:30 PM | #14 |
I got a nut on the end of a longer screw through the servo saver but it's still mighty crappy. It was fun on the baseball field, though Sent from my SM-G900T using Tapatalk |
06-15-2016, 04:09 PM | #15 |
@ least you can run it and have some fun.
06-15-2016, 04:33 PM | #16 |
This sensorless motor and esc combo is crap. It got hot fast on 3S. It cogs like crazy at low speeds, too. Sent from my SM-G900T using Tapatalk |
06-15-2016, 11:02 PM | #17 |
It's definitely not made for crawling if that's what your doing with it Wait, where am I? |
06-15-2016, 11:53 PM | #18 |
06-16-2016, 07:48 AM | #19 |
I run fans on the esc and motor. Check your spur gear tooth count. Looks like your pinion is 15T. Might need to change your gearing to stay a bit cooler. Also make sure nothing is binding or causing excessive load on the motor, check the gear mesh.
06-16-2016, 09:17 AM | #20 | |
Need help identifying parts on yeti I picked up - Similar Threads | ||||
Got the U4 bug and picked up a yeti with loads of vanquish parts | hillbillybob | Axial Yeti | 0 | 09-04-2015 05:27 AM |
just picked up a used Yeti XL today | Megadesertdiesel | Axial Yeti XL | 14 | 05-21-2015 12:07 AM |
just picked up a yeti | ullose272 | Axial Yeti | 13 | 02-20-2015 07:35 PM |
Picked up a Yeti XL recently.... | MachLid | Axial Yeti XL | 3 | 12-07-2014 09:22 AM |
Need some help identifying some parts | Hitman Cody2130 | Axial AX-10 Scorpion | 2 | 09-01-2012 11:58 AM |
