08-15-2016, 03:33 PM | #1 |
| New Chromoly AR60 Rear Axle Shafts
New rear axle shafts for all AR60 axles are available now! Made from high quality heat treated chromoly steel. Low price and available now! AR60 Rear Axle Shafts - Vanquish Products |
08-15-2016, 08:24 PM | #2 | |
Rock Crawler Join Date: Mar 2014 Location: Dallas, Texas
| Re: New Chromoly AR60 Rear Axle Shafts Quote:
08-15-2016, 09:59 PM | #3 |
Rock Stacker Join Date: Jun 2015 Location: Azusa
They're crazy stronger and will not bend as easily highly recommended for the price! Sent from my iPhone using Tapatalk |
08-15-2016, 11:43 PM | #4 |
Newbie Join Date: May 2016 Location: Lodi
will they fit inside beef tubes w/o grinding?
08-16-2016, 01:00 AM | #5 |
| Re: New Chromoly AR60 Rear Axle Shafts |
08-16-2016, 05:06 AM | #6 |
Newbie Join Date: Jul 2015 Location: Bacchus Marsh, Australia
Be nice if you did away with the holes that's where they usually bend. Sent from my Nexus 10 using Tapatalk |
08-16-2016, 06:32 AM | #7 | |
I've been designing a new rear axle in my head for months now trying to get away from that hole. If it wasn't for that hole even titanium would be a viable material. The end of the axle could be splined for a hex or slw type hubs but the size limitations of the current straight axle ends makes the minor size of the splines smaller than the axle so they'd be weak. The 5x10 bearings really limit the axles. | |
08-16-2016, 07:40 AM | #8 |
Quarry Creeper Join Date: Jul 2010 Location: The Ocean State
Hope they hold up better than the VVD's....
08-17-2016, 09:25 AM | #9 | |
Rock Stacker Join Date: May 2015 Location: CF
Thanks. Sent from my Nexus 6P using Tapatalk | |
08-21-2016, 07:22 AM | #10 |
Bought them. I am rebuilding pretty much my entire Yeti. These are going in. Also picked up some vanquish stickers. I hope this cures the bent axle issue. Sent from my iPhone using Tapatalk |
08-22-2016, 08:02 PM | #11 |
Quarry Creeper Join Date: Jul 2015 Location: Winter Park Colorado, 8000Ft Elevation
Now if they could just design a better way of attaching the lock-outs. They get sloppy and loose pretty quickly. I finally rotated mine 90* so the clamping bolt is on the top and tapped a screw into the rear of the axle. When the acceleration torque is applied it is pulling the lock-out forward, hopefully this will help. |
09-03-2016, 01:34 PM | #12 |
Coming back to this thread, I installed the axles today. Mother of god, the stockers were horribly warped and twisted. Not only were they bent where the hubs attached, but they were bowed throughout their entire length. They had actually eaten through some of the plastic in the axles. Well, 2.2 swamper XLs coupled with a 2700kv 4065 motor running 3S at high speeds will do it. These axles feel like pure quality in your hands. Hard to describe. I look forward to seeing how these hold up. By the looks of it, I will need new diff gears soon and will have to open everything back up. Sent from my iPhone using Tapatalk |
09-03-2016, 08:48 PM | #13 |
As a further update, yup the ring and pinion are shot. 5 minutes after I get it all back together I need to take it all back apart. HD gears this time with fresh bearings. Sent from my iPhone using Tapatalk |
09-07-2016, 09:19 PM | #14 |
Rock Stacker Join Date: Apr 2016 Location: Fort McMurray, AB, CAN
| Re: New Chromoly AR60 Rear Axle Shafts SSD HD axles use a rectangular shaft where the hexes sit and no pin hole. Don't know why companies think that the pin hole will hold up with these tall tires and aluminum wheels.
New Chromoly AR60 Rear Axle Shafts - Similar Threads | ||||
New Chromoly AR60 Rear Axle Shafts | Harley | Axial RR10 Bomber | 23 | 08-25-2016 01:14 PM |
New Chromoly AR60 Rear Axle Shafts | Harley | Axial Wraith | 2 | 08-15-2016 05:05 PM |
