01-01-2017, 03:20 PM | #1 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
| Hello and looking for some help/recommendations for my Yeti kit build
As you probably guessed from the title I'm building a Yeti kit. I've wanted a Yeti since they first came out so I figured now was as good a time as any. I am trying to cover all the weak spots as I go concentrating on the harder to get at internals first. As of right now I have a Hobbywing SCT Pro esc with a 3656SD 3400 kv motor, SSD 2 speed gear set, SSD Wide Diamond rear axle, Robinson Racing gears for the transfer case and a MIP drive shaft. I plan after funds rebuild on getting Vanquish upper and lower rear control arms, aluminum Steering Knuckles and aluminum Front Caster Blocks. Robinson Racing Spur/ slipper assembly, STRC bellcrank and Axial machined adjustable motor mount. Any other recommendations would be greatly appreciated. Last edited by Rumpelhardt; 01-01-2017 at 03:23 PM. |
01-01-2017, 04:12 PM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Hello and looking for some help/recommendations for my Yeti kit build
Better screws as included in kit, CI Deuces Wild Foams, Better Wheels, SLW Alu Hubs, Steel pivot Balls, a few springs shock oil .... I would go with the SSD rear trailing arms instead of the Vanquish ones. Have Fun building it. U can find my upgrades in my thread My little Monster A Yeti for the Alllgäu or my little monster |
01-01-2017, 06:59 PM | #3 |
Thanks for the reply nice car. I see you and I have the same taste in driver heads lol. |
Hello and looking for some help/recommendations for my Yeti kit build - Similar Threads | ||||
Yeti XL kit build 6s | slowe2411 | Axial Yeti XL | 26 | 01-15-2016 07:57 AM |
Another Axial Yeti XL Kit Build | AztecAdvancements | Newbie General | 8 | 10-01-2015 11:44 PM |
Axial Yeti XL Kit - My first kit build | vashan | Axial Yeti XL | 19 | 09-01-2015 04:46 PM |
Yeti XL kit build - my way in the the PNW | Fowlboy | Axial Yeti XL | 28 | 07-18-2015 09:09 PM |
yeti kit build problem | tuba6869 | Axial Yeti | 1 | 02-08-2015 04:22 PM |
