GCM Transfer Case Well, here's the T-Case. Me and the boys here love these things. The all new, and all Canadian, no gearing gain/reduction GCM Transfer Case available here at gcmachine.ca I have never been too impressed with aftermarket gear manufacturing. I keep finding wimpy brass gears, soft driven shafts, and low class mounting and setscrews. (although there's some real nice stuff here in this forum! wow) And I can't stand breakdowns on the trail. The remedy for this, and the only way we do things, is to over build for durability and strength, but simplify for size, and look. Here's what we came up with: 1) Fully hardened steel drive gears with wide teeth, and big set screws made from oxide steel.... unbreakable tough. 2) Hardened and ground axle drive shafts made specifically for axial torque and precision bearings. With nice deep and wide flats for setscrews to bite hard into and stay there. 3) Stainless steel bearings with debris shielding. This case is going to be in the mud, the dirt, the water, all the crap you can find, and it has to turn your wheels for miles with no repairs. This is the ticket. 4) Billet aluminum fully machined matching case halves. So what? It's important. Both halves are made in perfect matching sets and machined together in order to have a flat and strong interlocking seal between the front and rear sections. Funny, but even if the screws fall out, and you have driveshaft yokes screwed on to the thing, it won't fall apart. But locktite the screws anyway. Available in the 'Complete Kit' that has everything included. See the site link above for any other details you need. All kits require assembly. On with the business: http://gcmachine.ca/images/tcase010.jpg http://gcmachine.ca/images/tcase012.jpg http://gcmachine.ca/images/tcase013.jpg http://gcmachine.ca/images/tcase014.jpg http://gcmachine.ca/images/tcase015.jpg http://gcmachine.ca/images/tcase016.jpg Add your own drive shafts, like shown below, and you have a running truck that can take more punishment than you can deliver. http://gcmachine.ca/images/tcase017.jpg Here's the full assembly instructional video: Assembly Instructional Video Link For those who don't know GCM, is a full service 3d cad and CNC shop in Canada, and has been producing and selling RC parts worldwide for years. We also entertain machining jobs for other designers and production for anyone, as well as our own line of crawler and offroad parts. We rotate through our production runs every 4 or 5 weeks, so anything out of stock in the store will be back soon enough. Thanks. |
Price, without goint to the Website? @ work |
the price of a complete t-case kit is $69 canadian funds, which at today's exchange rate is close to $69 usdollars. Shipping is determined by the shopping cart and is likely under $12. Check the gcmracing.ca site for updated pricing, and use the shopping cart for shipping details. |
nice sales pitch, killer product, and great size! |
and out of stock already :cry: |
I' guessing, but T-E MAxx shaft's won't fit right? Will you offer shafts without the flat portion? and just holes instead. Are the shafts exactly 5mm, or more like 4.95? How much for just the case without gears, bearings or shafts? would you sell it just like that? I could use a few if they' could come like that. <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"> |
You guys will love this tcase, i just recieved mine and its a work of art, great products from GCM thats for sure"thumbsup" |
the cases alone are available by custom order alone, simply e-mail the company through the links in the signature. I am still waiting for my big gear order to come in, and that's what the delay in stock is from. The shafts are machined with flats, we may try holes for a custom order, but the shafts are 5.0000 mm ground and hardened before machining, and a drill isn't going to like that much. If you use a CVD like an MIP style, there are easily interchangeable ends for them so it's possible to use a 5mm t-case end and a 6mm other end if need be. The 6mm shafts will fit using a sleeve for 5mm to 6mm which we also sell in hardened stainless. We will post a specific part for this exact application on the t-case page when they are available. We have been making these for years for other applications, and they work great. Below is a picture with all 5mm shafts, and as you can see, the case is tiny. The 6mm shafts will fit (4951x style) but the revo or 3.3 shafts will not. http://gcmachine.ca/images/tcase004.jpg |
Just ordered the "starter kit" we'll see how it turns out. I'll write a small review and can compare it to a CC case <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"> |
Would it be possible to get this in a 6mm shafted version? EDIT: Of course I didn't read your last post. I did the other day though...seem to have forgotten. |
Here's a picture of the CrossCanyon Skidplate that matches this T-Case. It houses your lower links internally, and allows the direct bolt on of the T-Case in right or left configuration to keep the drive axles in the center line. You can also bolt the case on to have the axles offset right or left. The Skid is fully machined delrin and has holes in the top surface to accept any M3 size screw, threaded directly into the skid, so there's no screw heads out the bottom of the unit. http://gcmachine.ca/images/ccsk016.jpg http://gcmachine.ca/images/ccsk017.jpg This unit is a direct bolt on for the GCM CrossCanyon chassis, as well as anything that accepts the stock axial crawler skidplate, and it matches a stock axial crawler width. |
This is very nice! I like the fact that your skid is interchangeable with Axial skid plates, very nice! One question though, are those threaded inserts int he top of the skid or is it machined with that extra material like a stand off? |
Great question. The entire skidplate is virgin Delrin material and completely machined. There's a taper-started hole that's 8mm deep inside the bosses that stick up, and they are drilled perfectly to self-thread a m3 machine screw in there. No insert is present, and the holes are not tapped. The machine screw makes a perfect thread in there on it's own. All the material you see is Delrin one piece. The plates are 80mm wide and 43 long and have a 34.3mm hole spacing for mounting through for the internal links. |
Awesome! I hpoe to be placing an order some time soon for a skid and case. "thumbsup" Thanks for the super fast reply as well! Quick question, what length screws would I need to attach the case and not bugger up the skid? |
well as stated, with a 8mm hole in there, and another 3 on the Tcase mount, a M3x8 or M3x10 would do. By the way, I am not sure if you know this trick or not, but run the screws into the skid part way a couple of times before going all the way down. The screws tend to air-lock in the hole and make a pop if you don't. haha. A powerdrill and hex drive work great for this ! |
Opps lol :ror: Thanks! Looking forward to making an order soon. "thumbsup" |
Here's some pics of the black t-case mounted on a new delrin skid. The t-case sits on top of the bosses on the skid, and then the m3 screws thread into the skid and it's not going anywhere. And with the bottom smooooooth and the links internally mounted, it should be a clean sliding setup. http://gcmachine.ca/images/ccsk018.jpg http://gcmachine.ca/images/ccsk019.jpg The T-Case unit is 48.4mm long x22.4mm wide x22mm high. |
Sweet tcase! You have some great products! I think I found my next scaler set up b/c I have a pair of axles begging for a project. When the time comes I'll be ordering up a chassis, skid, tcase and motor mount."thumbsup" |
Perfect fit for my 6x6 build, order placed.. Thanks! "thumbsup" |
Well hell yeah. I'll have to order one of these in a week. Nice! |
