02-23-2012, 01:41 PM | #1 |
| DLUX SUPER parts
Like my Berg thread, I am just going to lump everything together in here so I dont clutter up all the vendors sections and to make things easier to find. In this thread I will have ALL the super parts I have to offer, Berg, Bully etc,. This will be a work in progress for now. I wont have this on my website or even have this thread completed for a bit. I just want to get the parts out there for those who are interested. PM me for more info for the parts that are not on my website or incomplete in this thread. Wheels Currently only being made to work with Trencher sidewalls (I think Moab may be the same?). These will be the same style as my 2.2 and 1.9 wheels. Finally a super wheel with:
Starting at $107 for a pair of wheels. Delrin tubes These only mount up to a Berg gear box currently. I can make them to size if you want them for your Berg or if you want to make them for a Berg/Bully type axle. $150 for tubes and shock mounts Super servo mounts These are made to fit a 7980 only. I can make them for a 7950 if there is a demand also. More heavy duty than my standard 2.2 mounts as these have 5 mounting holes rather than 3. $15 ea Battery mount This mount goes between your servo and servo mount. No straps or o rings to secure the battery are included. $15 Electronics mount This comes off the gear box panel on the Berg and goes behind the gearbox itself. I will try and get the measurements later. $25 Bully knuckle weights No longer avail Links I can make any link you need. Steering, suspension etc,. I can also make them from 3/16" or 1/4" TI or 3/16" AL. Other options could be avail but that is what I keep on the shelf. 3/16 Al $18 pair 3/16 TI $29 pair 1/4 TI $39 pair Add $10 to each pair for custom bends. Berg upper link mounts Comes with the middle aluminum brace. $20 Last edited by Erik D_lux; 03-12-2013 at 10:15 PM. |
02-23-2012, 01:42 PM | #2 |
| Re: DLUX SUPER parts
Services:
02-23-2012, 01:42 PM | #3 |
Saving 1
02-23-2012, 01:42 PM | #4 |
Saving 2
02-24-2012, 05:45 AM | #5 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Very sweet Later, Farmer |
02-24-2012, 09:41 AM | #6 |
$150 is very reasonable for the tubes IMO. Mine have held up to some serious 4s brood motor abuse and my crazy driving. I also like that there is no outer shaft bearing, and the tubes tolerances are tight enough with the axle shaft to essentially combine their strength. Also tight enough to keep out dirt. They certainly played a role in getting my super down to 7lbs and getting a good finish at nats. Thanks for the cool parts Erik! And just an FYI I'm not sponsored by dlux in any way. |
02-24-2012, 12:31 PM | #7 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Awesome parts! It's good to see a vendor supporting the Super Class. Thank you for that! Can the super wheels be had in Black?? Pretty sure you just drove your ass off...but it's a good plug for dlux, so I'll let it slide Last edited by TURBOFEST; 02-24-2012 at 12:34 PM. |
02-24-2012, 12:32 PM | #8 |
Is my stuff ready yet? I cant wait....... |
02-24-2012, 12:55 PM | #9 |
Rock Crawler Join Date: Mar 2009 Location: houston
| Re: DLUX SUPER parts |
02-24-2012, 01:41 PM | #10 |
02-24-2012, 07:56 PM | #11 |
Wow. Really not expecting any response at all from this post. I just wanted to put everything up as an option for people. Thanks a bunch to everybody for all the orders already! Now I need to get to work. |
02-24-2012, 08:23 PM | #12 |
Awesome work and idea's! I am interested in the servo mounts, could I send my tubes to you to make them work?
02-25-2012, 01:39 AM | #13 |
| Re: DLUX SUPER parts Sorry, I just realized I missed this earlier. Yes, wheels can come in black, white or a clear face. Pretty much all the same options as my 2.2 wheels and more. You just need somebody to drill and tap for the servo mount? If so, yes, I can take care of that too. |
02-26-2012, 11:11 AM | #14 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
I'm in for the super bully knuckle weight mounts. Let us know when it's available.
02-26-2012, 11:19 AM | #15 |
03-02-2012, 01:01 PM | #16 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
Wheels are a GTG sign!! Black would be excellent. any way to do a spoke design like the HPI blasts? Any plan to do 17mm hex centers? |
03-02-2012, 01:26 PM | #17 |
Black is no problem. I have 2 sets of black sitting here. When they are done I will post up. I can do a face design, you would definitely have to bump the face thickness up to 3/16, maybe more depending on the weight of the car. What is the benefit of doing a 17mm hex? If you could find a bolt on hub I can probably accommodate. |
03-07-2012, 08:54 PM | #18 |
Quarry Creeper Join Date: Feb 2009 Location: Glendale Az
looks like I picked a great time to build my super....btw are those xr10 knuckles on your tubes?
03-07-2012, 11:54 PM | #19 |
They are Bully knuckles and shafts and a Berg case. |
03-08-2012, 07:03 AM | #20 |
DLUX SUPER parts - Similar Threads | ||||
DLUX Berg axle parts | Erik D_lux | Axles, Trannys, T-case | 144 | 11-18-2019 10:50 AM |
DLUX super build | Erik D_lux | Superclass Crawlers | 578 | 07-20-2016 09:13 AM |
~53 willys DLux Style Super Berg~ | 53 willys | Superclass Crawlers | 112 | 01-27-2012 01:05 PM |
Show me you DLUX parts pics please. | TedBull | Losi Mini-Rock Crawler | 13 | 01-08-2012 01:48 AM |
