07-07-2012, 04:31 PM | #21 |
Pebble Pounder Join Date: Dec 2010 Location: clio mi
| Re: Nordic Crawler Design Axial XR10 70 Degree Steering Kit
payment sent for a full kit |
07-07-2012, 11:01 PM | #22 |
RCC Addict Join Date: Oct 2008 Location: Finland
| Re: Nordic Crawler Design Axial XR10 70 Degree Steering Kit |
07-12-2012, 09:51 PM | #23 |
Quarry Creeper Join Date: Jul 2007 Location: WA
Got my kit today and installed on my sportsman modified with wraith Knucks. 70 deg is achievable with the arms. I'm at 70 with tires stuffed into the links. About 65 with them just touching the links. This kit made the steering links easier to fit which was a bonus. The ti one you sent almost works out but rubs the link plate posts. Thanks again. Great fit and finish.
07-12-2012, 11:27 PM | #24 | |
| Re: Nordic Crawler Design Axial XR10 70 Degree Steering Kit Quote:
A pic or two would be nice. | |
07-13-2012, 09:42 AM | #25 |
07-16-2012, 04:28 PM | #26 |
Got mine Saturday, everything looks great, thanks! |
07-17-2012, 04:43 AM | #27 |
RCC Addict Join Date: Jun 2009 Location: Australia
All my parts arived today, with my sons health issues i have not had a good look yet , but from what ive seen looks good mate When i get the chance il update on my local forum and see if you can get any more local guys buying your gear |
07-17-2012, 06:22 AM | #28 |
I got mine in yesterday as well. Tomy, can you post a picture from the bottom showing the tie rod mounted up? I just wanted to compare my angle to how you designed this kit. BTW, the steering angle is incredible! |
07-18-2012, 04:46 AM | #29 |
Sorry for the late reply. I was not well for a few days but am now back on my feet again. Here are pics of my setup. I'm using a v1 tie rod made early this year. It is a bit on the shortish side, which is why there's a lot of thread showing past the rod end. With the tie rod included in the kit, you should have just a little bit thread seen and room for more adjustability. Shoot for a 178,5mm distance eye to eye with the Revo rod ends. That should give you a neutral position in terms of toe in/toe out. Once the tie rod is fastened , rotate it so you find the sweet spot where it isn't rubbing your motor or the axle housing. You might find you will slightly want to increase or decrease the bend in the tierod to adjust clerance. This is easily done in a wise. The kit was designed to work with caster set to max without any modifications done to the knuckles or c-hubs. If you find you don't get all the potential out of your setup, look for clearance issues at the servo. You might find that the rod end or mounting screw of your drag link hits the servo: Or that the knuckle end of the draglink hits the c-hub: |
07-18-2012, 07:22 AM | #30 |
Pics look good Tomy. Can't wait until I get a chance to get my gear unpacked from you and onboard my wedge. Ben Sent from my GT-I9100T using Tapatalk 2 |
07-18-2012, 07:32 AM | #31 |
Thanks Tomy, that's exactly what I was looking for....and that's how I have mine setup. BTW, in this picture: I see that you are running the VP upper link mount......you can slide that servo mount over one hole and drill out the slot in your servo plate some and shift the entire servo toward the center of the axle. This will give you a bit more clearance for your tire and servo horn. |
08-17-2012, 02:39 AM | #32 |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: Nordic Crawler Design Axial XR10 Steering Kit
For some reason I missed this thread .... nice set Payment send !
08-17-2012, 05:37 AM | #33 |
Rock Crawler Join Date: Feb 2009 Location: LaGrange
where do i get the weights for this system
08-18-2012, 11:04 PM | #34 |
RCC Addict Join Date: Jul 2006 Location: barstow
| Re: Nordic Crawler Design Axial XR10 Steering Kit |
08-21-2012, 08:49 AM | #35 | |
| Re: Nordic Crawler Design Axial XR10 Steering Kit Quote: thank you sir | |
08-28-2012, 01:04 AM | #36 |
I will be busy at my day job next week. Nordic Crawler Design will be closed from September 3rd to 9th. I will answer all pm's and emails, but can not make parts during next week. All open orders and orders placed before Friday August 31st will ship normally. Thanks! Tomi |
09-05-2012, 05:00 PM | #37 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
09-14-2012, 02:12 AM | #38 |
Taking new orders again.
09-14-2012, 03:42 AM | #39 |
Hey mate got mine all setup sweet now, fixed the servo horn hitting the servo by doing as suggested above and moved the servo furthest toward the centre. modded the axels as you described in the universal. Works awsome for anyone thinking of these, Highly recommended. Sent from my GT-I9100T using Tapatalk 2 Last edited by Oz Bruiser; 09-14-2012 at 03:44 AM. |
09-14-2012, 06:32 AM | #40 |
Thanks for the tech, Ben. |
Nordic Crawler Design Axial XR10 Steering Kit - Similar Threads | ||||
Nordic Crawler Design Knuckle Weight System for VP XR10 and Wraith Knuckles | Tomy | Axles, Trannys, T-case | 94 | 04-18-2014 09:44 AM |
Nordic Crawler Design Carbon Fiber Axial XR10 Rear Axle Brace | Tomy | Axles, Trannys, T-case | 8 | 02-26-2013 08:04 PM |
Berg Steering kit (renoirbud design) | renoirbud | EnRoute Berg | 6 | 10-06-2009 11:52 AM |
