03-06-2013, 09:37 AM | #21 |
Pebble Pounder Join Date: Nov 2012 Location: Silver Springs, NEVADA
.. Sent from my HTC One VX using Tapatalk 2 |
03-06-2013, 07:13 PM | #22 |
RCC Addict Join Date: May 2010 Location: Midwest
| Re: GripFab "Grip-Lok" Spool!!
Thanks guys! All orders placed on or before 3-4 were shipped on 3-4. All other orders will ship 3-7. |
03-07-2013, 01:01 PM | #23 |
RCC Addict Join Date: Aug 2011 Location: Pipersville
Got mine in today. They look awesome. Will be getting they other set too.. Thanks Rick |
03-07-2013, 03:24 PM | #24 |
Quarry Creeper Join Date: May 2010 Location: Flooriduh
Got home from work and found Grip Fab spools in my mailbox. You must be using RPP's Shipping Guy.Don't have them in yet but I did slide a stock Axial axle in them. Nice tight fit Vary well made. Thanks again Rick. |
03-08-2013, 05:41 PM | #25 |
Didnt see the weight in this thread, so here it is. 6 grams each. Good stuff. Thanks. |
03-08-2013, 06:16 PM | #26 |
I've got a STUBBY! Join Date: Apr 2011 Location: Newcastle Australia
Shipping cost for a pair to Australia 2280? Josh |
03-10-2013, 10:30 AM | #27 |
PM sent. Thanks for the orders guys. ..and thanks for posting the weight Szczerba |
03-10-2013, 02:24 PM | #28 |
Just put the spool in my Wraith. Had to modify the gear.. I know it's designed for the. Ax/scx10 but I am curious. We will ser what happens Sent from my HTC One VX using Tapatalk 2 |
03-10-2013, 09:22 PM | #29 |
Ahh, you must be speaking of the 2 tabs that stick off the the factory stock ring gears. Is that what you had to modify? These spools do not have provisions for those 2 tabs as they were designed around the Hardened Axial ring & pinions which do not have those tabs. I don't believe it has anything to do with SCX10 vs. Wraith.. I believe those two rigs to be the same as far as axle construction goes. Glad to hear to go it taken care of.. you should be good to go |
03-16-2013, 01:31 AM | #30 |
Ok, I have more Spool's fresh off the machine & READY TO GO! |
03-16-2013, 04:17 AM | #31 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
Could you show a picture of these inside a scx10 axle? What's the difference between these, stock, and your grip lockers? What are the benifets here? Thanks in advanced. Last edited by cox308; 03-16-2013 at 04:22 AM. |
03-16-2013, 07:19 AM | #32 | |
| Re: GripFab "Grip-Lok" Spool!! Quote:
The Spool's are light weight and easy. They require no setup.. Just bolt them on and go. The flats on the axle shafts simply slip into position inside of the Spool for a snug fit. The Spools are ideal for plastic SCX10 housings because they don't require any modification to the housing. The Lockers are heavy duty, "no-slop", set screw clamping Lockers. They utilize big M5 set screws on either side of each axle shaft that clamp down hard creating a "no-slop" situation. They require a little more setup and they are ideal for axle housings with removable differential covers so that you can access the set screws easier. The Lockers would require one to slightly modify a plastic SCX10 axle housing to allow access to the set screws when the axle halves are bolted together. They are both great. I use a Locker in the front axle and a Spool in the rear.. Just because. If I had plastic SCX10 or AX10 housings, I would go with the Spool because it's easier and works great. Those using VP housings, Wraith/Ridgecrest housings, VP Currie housings, etc.. I would go with either one you prefer. Both the Locker & Spool will work in any Axial compatible housing with little or no modification. Stock Lockers can be weak & loose. They are not machined pieces like these and there can be several components including plastic pieces. They are susceptible to failure. Thanks! Last edited by Die-Laughing; 03-16-2013 at 07:22 AM. | |
03-16-2013, 08:34 AM | #33 |
paypal sent for 2! |
03-16-2013, 12:40 PM | #34 |
03-16-2013, 10:09 PM | #35 |
I got two of em on the way for my ultra4 car! Thanks man!
03-17-2013, 08:23 PM | #36 |
Rock Crawler Join Date: Jul 2010 Location: St. Albans
Has anybody tested these yeat.
03-20-2013, 08:56 PM | #37 |
| Re: GripFab "Grip-Lok" Spool!! |
03-21-2013, 09:43 AM | #38 |
Quarry Creeper Join Date: Mar 2011 Location: over there...
Paypal sent pair of spools
03-23-2013, 02:11 AM | #39 |
Pebble Pounder Join Date: Mar 2011 Location: Humboldt
Have you made a new batch of these yet? If they are available I want a couple.
03-24-2013, 03:03 PM | #40 |
GripFab "Grip-Lok" Spool!! - Similar Threads | ||||
Idea: "pistol grip trainer box" for DX6i or 6EX | engineerjoe | Electronics | 6 | 06-19-2009 05:55 AM |
