Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Chassis and Suspension
Thread: **NEW From Reign - The Servo Crown (TM)**
Old 06-03-2008, 01:06 AM   #1
Est. 2003
PinchFlat's Avatar
Default **NEW From Reign - The Servo Crown (TM)**
NOW AVAILABLE
NEW From Reign Products - Servo Crowns (TM) Servo Armor (TM)
Tired of your $100+ servo getting scratched, bashed & trashed? Now you can protect it with The NEW Reign Products Servo Crown (TM) Servo Armor (TM)
The Servo Crowns will also drastically reduce any movement of the servo during use, due to weak servo posts. In short, Your servo will also be considerably stiffer due to the sandwich-clamping effect of the plate. This in turn will create more accurate & responsive steering performance.
  • - Helps protect your servo from impacts & abrasions
  • - Creates more accurate & responsive steering performance (When mounted with supplied hardware)
  • - Helps dissipate heat from the servo.
  • - Machined from .125” thick 6061 series aluminum plates
  • - Easily installation
  • - includes mounting hardware
ONLY $20 ea. Plus $2 shipping in the USA Includes 1 Servo Crown (TM) and mounting hardware.
To order Please PM me or email me at: uncleguppy@gmail.com
Protect your investment with The Servo Crown (TM) Servo Armor (TM) NEW From Reign Products.
Available NOW but Numbers are limited. So hurry and Order NOW!!
Check out the installation guide here: http://www.rccrawler.com/forum/showt...76#post1212076
Trademark Information: Servo Crown & Servo Armor may not be used without expressed permission from Reign Products.
PinchFlat is online now   Reply With Quote
Old 07-17-2008, 12:20 AM   #3
pinch you may want to edit you post and use this
the servo crown is pretty sweet but to bad i cant use one on my mount on the wk
Kranberry is offline   Reply With Quote
Old 07-17-2008, 01:11 AM   #4
Est. 2003
PinchFlat's Avatar
When all else fails... Stick it on with shoogoo... That's how I mounted them in my Super. Holds like a mother.
You may edit your posts
