02-12-2008, 07:00 AM | #21 |
wooden stand offs? looks great, crazy how it runs fine with all those problems are yall just gonna leave the crack? what did you find out about teh zenoah muffler fitting? |
02-12-2008, 09:42 AM | #22 |
Quarry Creeper Join Date: Jun 2007 Location: Sacramento
02-12-2008, 09:58 AM | #23 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Steel City, That's straight out of the box. There's a thin layer of clear on the wood (applied from factory) for fuel-proofing. Stang, Yeah, hardwood standoffs. Work great and strong as you'd want. If you remember the shots of Roy crashing his Patty, he had used wood standoffs to mount his engine. When he came down the left wingtip hit, then a hard hit to the nose. So hard, in fact that the fuse busted in two. The standoffs...just fine. The wood standoffs don't look as trick as aluminum, but they're staying. Unless I get the urge to machine some from aluminum... Roy re-drilled his prop hub. It's straight now and is tapped for 8-32 hardware. The crack in the carb adapter is fixed. It didn't suck air or anything, but Roy filled it and got rid of the locking washers that were used and substituted with flat washers. I found out about Zenoah mufflers fitting when I went to Roy's house and we tried two of his Zenoah G45 mufflers...direct fit. I'll probably order a Slimline Pitts with smoke this week. Last edited by JasonInAugusta; 02-12-2008 at 10:12 AM. |
02-12-2008, 11:10 AM | #24 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
cool. even though i don't know very much about R/C planes, Hanger 9 always looked like they made decent products.
02-12-2008, 11:24 AM | #25 |
Yeah, the hardware kits are nice too. Robart hinges, nice heavy-duty control horns, etc.
02-14-2008, 01:19 PM | #26 |
Prop arrived. |
02-14-2008, 05:01 PM | #27 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
Purdy When will we see shots of it in the air? |
02-14-2008, 05:39 PM | #28 |
It'll be in the air when I get it done. There's not much left (parts-wise) that I need to complete it. The exhaust and smoke pump is on the way. I have the servos for it. It needed seven total. The servos that came with the DX7 will go into it (specs are right on the money) and control ailerons and elevators, but I picked up a JR 8711 for the pull-pull system on the rudder. 400oz should keep the rudder in check. Throttle and choke servos can be anything, I'll use some standard servos there. Our cat clawed up the top of the left wing so I had to recover it. I've got the base color down, now it's time to add graphics. I also need to re-cover the left side of the fuse. I was watching a movie and using the heat gun to get wrinkles out of the covering...got to a good part of the movie, and forgot about the heat gun. Messed the covering up a bit near the nose. Most people wouldn't notice it, but I did. So...stripped that side of the fuse and need to recover it as well. I figure it'll be 2-3 weeks before I take it up. |
02-14-2008, 07:04 PM | #29 |
Pebble Pounder Join Date: Oct 2006 Location: Sault Ste. Marie, MI
How big is this plane? it looks huge from the pictures. Edit: clicked the link and saw the specs Last edited by CarsonWyckoff; 02-14-2008 at 07:07 PM. |
02-17-2008, 06:14 PM | #30 |
Finally drilled the prop tonight. Cleaned the workbenches so they were usable again. I'd do more but I've got a headache so bad right now that it hurts to move my eyes. Last edited by JasonInAugusta; 02-17-2008 at 09:36 PM. |
02-17-2008, 09:12 PM | #31 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
The metal scraps will surely make that particular beer potable. |
02-17-2008, 09:18 PM | #32 |
That cat would have "gone to a farm" if that had been my plane what did that 20 incher set you back? Last edited by STANG KILLA SS; 02-17-2008 at 09:21 PM. |
02-17-2008, 09:42 PM | #33 | |
| That's carbon fiber scraps. I didn't need to drill holes in the aluminum. The beer was leftovers from the first day of garage cleaning. Quote:
It was $60 for the covering to recover the wing. Much cheaper than the cat. The prop was $63 shipped. | |
