11-11-2004, 01:33 PM | #1 |
Rock Stacker Join Date: Feb 2004 Location: kelowna b.c canda
| best toyo truck ever made
okay i am looking to buy myself a truck (toyota) and i am thinking a toyota 4x4 with the r-22 motor and standared. what who you think is the best truck that toyota made that you think i could buy i have about 4 grand and i need much of that for tires and other mods
11-11-2004, 01:37 PM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Re: best toyo truck ever made
The motor is a 22R ;) You want a 1985 Toyota Truck or 4Runner (4Runners are SICK!). The reason for this is they are the first year of Fuel Injection (22RE), so its got a bit more power, and runs better overall. They are also the last year of the Solid Front Axle, which is VERY good. Cause, as we all know, IFS sucks! My only thing against 85 pickups is I hate the body style, I love the 79-83 style much more, but no EFI unless you convert it. The carb'd are still great motors (22R). Don't touch an auto in these things, they don't make much power and when you add a cruddy auto, it REALLY slows it down. For a kid like you, you'll probably want a 4runner to carry the chickies around ;) |
11-12-2004, 10:12 AM | #3 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Yup 85 Toyota. Just be aware that Toyota did do carbs until 87-88. So make sure it has EFI. You may find an 85 for really cheap but it maybe carburated. Just check first.
11-12-2004, 12:23 PM | #4 |
Newbie Join Date: Aug 2004
I agree with SR5 dave, i'd go with an 85, because of the 22re, the fuel injected 4 banger, the tranny are stronger (I read somewhere that the tranny in 79 to 84 models had weak trannys that needed to be beefed up in order to go wheeling), and I heard the front axle is trussed. I'd also go with a solid axle 4-Runner (years 84 or 85). Head on over to pirate4x4.com, they have a forum for Toyota 4 runners and Pick ups
11-12-2004, 06:42 PM | #5 |
I have an 87 X-cab that I've done a SAS on with fullwidth Chevy axles. I LOVE it. I,personally,like the 2nd genaration body style. If you've got any kind of heigth to ya,I'd recommend an X-cab if you can't find a 4Runner. The standard cabs don't have enough leg room for a guy taller than about 5'10" tall IMHO. I wish I had a 4Runner but I still am VERY happy with my X-cab. If I was gonna build another bodied rig,it would be an 85 4Runner,hands down.
11-12-2004, 07:52 PM | #6 |
Pebble Pounder Join Date: Aug 2004 Location: orange county n.y. , building the hydro crawler
when you did your sas was it a pita to drill through the chassis with the internal webing? ah i should get my torches filled anyway itd be alot easyer to cut everything off than with a sawsall. and did you weld your spring hangers directly to the front cross bar or did you first weld them to a lenght of square tube and then weld that to the bar? ive seen it done both ways just wondering. and im thinking about making the spring and shackel mounts about 2-3 inches lower to give some lift good or bad idea?ok one more question, sorry its alot, is the stock driveshaft able to run at the angle id need for the sas and lift? or will it not work and id make a shaft with cv joints? sorry again for so many questions |
11-12-2004, 10:13 PM | #7 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
What are your plans with the Toyota? Rock crawling, mud, prerunning or?? sambmx..... Some SAS info from a swap I did here: http://www.4x4wire.com/toyota/tech/mini_frontsusp1/ The IFS CV won't have enough angular movement for SAS conversion. You'll need to cannabalize a solid axle shaft or use some other shaft. If you go with long travel front springs you'll want an aftermarket shaft with at least 6 inches of spline travel. Jay |
11-13-2004, 08:01 AM | #8 |
Thanks alot its a good write up on it , answered all my questions. Im going to do my own driveshaft maby with some high angle pto joints.
11-13-2004, 08:17 AM | #9 |
RCC Addict Join Date: Jun 2004 Location: SERCRC
| Re: best toyo truck ever made After cutting all of the spring hangers off of my '85 and moving them around for my longer springs, and mounting a IFS box for the crossover steering, it would probably been just as easy to start with a IFS truck and do a SAS. Here's a link to my 'build-up' thread on Pirate4x4. http://www.pirate4x4.com/forum/showthread.php?t=220551 I sold the truck to RXCrawler last week..... hope he has fun with it! |
11-13-2004, 09:27 AM | #10 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
hands down the 1985 toy is the best. i have one with efi but i dont wheel it i have a jeep for that. toyta/jeeps best wheelers |
11-13-2004, 11:12 AM | #11 |
bendforthebone Join Date: Feb 2004 Location: Jamul
tacoma
11-13-2004, 11:44 AM | #12 | |
| Re: best toyo truck ever made Quote:
NO! You are so wrong. The tacoma is a great "truck" for people who want something cushy. Which is not a truck. Its a car. If you want to spend tens of thousands on making a wheeler out of it, maybe. But still, shtty. | |
11-13-2004, 11:52 AM | #13 | |
Crazy. I never linked the two CSR's together, even with the whole bolding all your posts. Cool to have ya on! | |
11-13-2004, 12:03 PM | #14 | |
11-13-2004, 12:19 PM | #15 |
Whatever works dude! As for Steve's comments on cab size... Yes, single cabs are small, but you can manage in them just fine, I'm not exactly what you'd call a small person and I fit alright. Could be better but I'm not complaining. Defintely room for improvement though. With a 4Runner though you don't have to worry ;) And most if not all 85 Runners are EFI |
11-13-2004, 02:28 PM | #16 | |
Quarry Creeper Join Date: Jul 2004 Location: 808
Give it a few more years and youll see alot more tacomas out on the trail. Check out the TTORA forum/site, some guys already have verry capable tacomas. | |
11-13-2004, 04:44 PM | #17 | |||
Tacoma's have their place... IMO its not a good wheeler, and the only way to get it to be is to change out a ton of stuff. Probably a nice DD though. | |||
11-13-2004, 04:52 PM | #18 |
Back to my question.......what do you want to use it for?? Jay |
11-13-2004, 05:22 PM | #19 | |
11-13-2004, 08:51 PM | #20 | ||||
