12-24-2011, 02:39 PM | #1 |
Quarry Creeper Join Date: Sep 2010 Location: Maine
| Snowmobile guys
So I started my sled up and itll idle around 2000 rpm but I let it sit and it dies. Ive sinked the carbs and do everything to make the 3 carbs the same. What did I do wrong? by the way i got a 1995 Polaris XCR 600 |
12-24-2011, 03:24 PM | #2 |
Nobody Join Date: Sep 2008 Location: Maine
| Re: Snowmobile guys
When it's about to die will it perk up if you pull the choke? Probably need to tweak the air screws or adjust the idle a little higher.
12-24-2011, 03:32 PM | #3 |
Quarry Creeper Join Date: Mar 2008 Location: N. Ridgeville , Ohio
| Re: Snowmobile guys
Could be a clogged pilot circuit. Will it run on choke, but die when the choke is turned off? |
12-24-2011, 04:07 PM | #4 |
Quarry Creeper Join Date: Jul 2005 Location: In my shop
| Re: Snowmobile guys
Triple carbs,triple the problems!JK...Did you thoroughly clean them?Probably a clogged circuit.Did the sled run ok last season?I use Stabil in my sleds and bike and it really seems to help during storage.Also if you had the carbs off make sure the carb boots are full seated,could be an air leak.I just picked up a 05 Ski Doo Renegade and am praying for snow.Any snow by you?
12-24-2011, 06:58 PM | #5 |
Quarry Creeper Join Date: Jan 2009 Location: Elko Co.
| Re: Snowmobile guys
Make sure floats are all where they need to be and nothings sticking on you. I had a 96 xcr and finally sold the pos because of constant carb issues. lol. Such a fun sled though when running good...rare but fun!!! P.s. Also spray some wd40 around the boots like above poster mentioned and if it revs up you will know its leaking. |
12-24-2011, 07:22 PM | #6 | |||
| Re: Snowmobile guys Quote:
12-25-2011, 10:32 AM | #7 |
RCC Addict Join Date: Aug 2007 Location: Seattle
| Re: Snowmobile guys
How fresh is the gas?
12-25-2011, 08:56 PM | #8 |
| Re: Snowmobile guys
fresh. i drained every drop out of it
12-26-2011, 11:20 AM | #9 |
Donkey Punch Champion! Join Date: Oct 2006 Location: Minneapolis
| Re: Snowmobile guys
Buy a new one. It's a 1995 triple for Pete's sake. Coolest sounding motor, triple cylinder with triple pipes. Good luck. |
12-26-2011, 07:44 PM | #10 |
| Re: Snowmobile guys |
Snowmobile guys - Similar Threads | ||||
Looking for ideas on an RC Snowmobile | MtnMan210 | Non Crawler RC's | 22 | 12-26-2009 04:15 PM |
Any snowmobile riders | '83 chevy | Chit Chat | 15 | 01-30-2007 11:10 PM |
