12-08-2014, 12:11 PM | #21 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: i need alternative heat in my garage. need advise.
I had a thought on the home made hot air system. MAKE sure there is a provision for fresh air in. In a sealed system you might run into co2 build up. Probably designed into it, but I had a uncle die from a bad heater so it is always on my mind.
12-08-2014, 03:43 PM | #22 |
Quarry Creeper Join Date: Nov 2012 Location: Paxton
Thanks for everything guys and to the grammar ninja, there's a reason why I'm a welder not a language teacher. For the hot air duct system if I choose that. I was going to pressure check the fire box to the air duct before I cut the door opening. I can't remember if I mentioned the reason why I want to use wood fire. It's because I can get the wood for free by the truck load. |
12-09-2014, 03:36 PM | #23 |
I just got off the phone with my insurance company, they said as long as the burner itself is not in the building I'm good to go.
12-09-2014, 04:31 PM | #24 |
Rock Crawler Join Date: Jul 2011 Location: USA
I know plenty of people that use a wood or pellet stove to heat a garage. Its pretty cheap and effective, especially if you can score wood for cheap or free. If its safe enough to use in a house, i dont get why they would be against one in a garage. I know plenty of people that have them in their homes too. |
12-09-2014, 07:26 PM | #25 |
| Re: i need alternative heat in my garage. need advise. No pump needed, the steam pressure does the work.
12-11-2014, 04:49 PM | #26 |
I've decided on the forced air system. I talked to a HVAC installer today and he told me for my application the forced air system would be best. So now it's time to find parts.
i need alternative heat in my garage. need advise. - Similar Threads | ||||
Scale Garage builders Advise Needed! | Bananaclip | Scale Accessories | 3 | 11-18-2014 04:11 PM |
Heat Shrinking - Lighter or Heat Gun? (Is there a DECENT Cordless Heat Gun?) | MailManX | Newbie General | 22 | 01-30-2014 02:24 PM |
Mikes garage of doom garage comp.... | scorpion_ax | Videos! | 1 | 12-18-2012 09:37 PM |
Alternative to Spazstix | mongoose | Paint and Body | 1 | 05-05-2011 02:36 PM |
Alternative Batteries? | Going Up! | General Crawlers | 13 | 12-20-2006 11:01 AM |
