Go Back   RCCrawler Forums > Miscellaneous > Chit Chat
Thread: ECX 1/24 Barrage
Old 12-04-2017, 10:45 AM   #1
Default ECX 1/24 Barrage
Well I pre-ordered a orange 1/24 barrage from my local hobbytown usa store. It should be here before Christmas hopefully. If so my wife said I can't have it until Christmas. Has anybody else pre-ordered ?
casper975 is offline   Reply With Quote
Old 12-05-2017, 07:00 AM   #2
Default Re: ECX 1/24 Barrage
Hi casper,
I saw that there was no way to get one all the way here to me in time for Christmas with that late December release date. Fortunately, I caught a Facebook post about this VERY similar rig, and grabbed the last one asiatees had in stock!
https://www.asiatees.com/display.php...=All&id=147326
Mongol Pete is offline   Reply With Quote
Old 12-05-2017, 05:40 PM   #3
That one looks like the FTX mini outback.
Old 12-08-2017, 08:08 AM   #4
from the pics I have seen the FTX and ECX look to be the identical trucks minus a few differences, (tires, body, LED lights, etc.) I pre-ordered one for my son from RPP. Looking forward to trying it out. Its prety much same price for both in USD.
tgh117 is offline   Reply With Quote
Old 12-08-2017, 02:46 PM   #5
I hope it's here by Christmas
Old 12-09-2017, 12:54 PM   #6
Pre order the 9 December!
1/24 Barrage 4WD Scale Rock Crawler RTR - Blue (ECX00017T2)
For the inside of the house and in my garden.
I will receive it at the end of December. I can not wait to try it.
Yvan
MysTiC27 is offline   Reply With Quote
Old 12-09-2017, 01:56 PM   #7
Moderator
I'm planning to get one from my local hobby shop as soon as he gets them. I want to try designing and printing a new trans with a lower ratio.
Jim85IROC is offline   Reply With Quote
Old 12-09-2017, 02:39 PM   #8
There website says the 19th
Old 12-10-2017, 11:39 AM   #9
Specs:
pproximate Assembly Time: No assembly required
Batteries: 4.8V 220mAh NiMH Pack (Included)
Body: Cab with Scale Cage
Bushing Material: Metal
Charger: USB (Included)
Chassis: Ladder Frame
Completion Level: Ready-To-Run
Differential: Locked
Drivetrain: 4WD
Front Track: 4in (102mm)
Ground Clearance: 0.5in (13mm)
Height: 4in (102mm)
Length: 9in (229mm)
Motor Size: 050
Motor Type: Brushed
Painted or Clear Bodies: Painted
Pinion: 12T
Radio: ECX 2.4GHz 2-Channel (Included)
Rear Track: 4in (102mm)
Servos: Yes
Shock Type: Spring Loaded
Size/Scale: 1/10
Speed Control: Yes
Spur Gear: 64T
Suspension: Multi-Link Solid Axle
Tire Diameter: 1.8in (46mm)
Tire Tread: Mud Terrain
Vehicle Type: 4WD “Scale” Rock Crawler
Water-Resistant: Yes
Weight: 0.5lb (0.2kg)
Wheel Diameter: 1in (25.4mm)
Wheel Type: Black 8 Spoke
Wheel Width: 0.6in (15mm)
Wheelbase: 4.8in (121mm)
Width: 4in (102mm)
ECX 1/24 Barrage - Similar Threads
ecx barrage 4x4pornstar 1.9 Scale Rigs 12 07-12-2017 11:45 AM
ECX barrage Cpyonker General Crawlers 7 12-21-2016 09:18 PM
