09-02-2007, 04:34 PM | #21 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
This speed test was done with a Tamiya speed tester. The test car sports AWD, Carbon Fiber Drive Shaft, RS open bearings, Lithium Power, 4 FET Stack, and the new Nuke 130SM Super Modified Motor. http://video.atomicmods.com/Speed_Te...e_130SM_LG.wmv |
09-02-2007, 05:02 PM | #22 |
Rock Crawler Join Date: Jun 2006 Location: Oak Lawn, Illinois
09-02-2007, 05:06 PM | #23 |
RCC Addict Join Date: May 2006 Location: Aroostook county
09-02-2007, 05:07 PM | #24 |
09-02-2007, 06:13 PM | #25 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
How about putting a screw in and not noticing it went through 3 wires? That took sometime to solder back on. I tried to get back into it a few days ago but I finally just said fawk it and went slot car racing.
09-02-2007, 06:21 PM | #26 |
09-02-2007, 07:01 PM | #27 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Took a look at my xmod, and found it's tires to be about 1" in diameter. A liitle math later, I realized that 90mph with 1" tires means a tire RPM of 30,000. That is a helluva secondary driveline that can handle 30,000 RPM. |
09-02-2007, 07:07 PM | #28 | |
spinning your wheels on a KMA dyno wanna-be is a whole different thing then running down an actual course. I still have seen no proof of a fast xmod | |
09-02-2007, 07:41 PM | #29 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
There is now way in hell that a xmod will do 60 mph...the only way that will happen is if you throw it off a cliff or out of a car doing 60. Your starting to sound like Krawlin with his 30bps walmart paintball gun. There MIGHT be a hand full that can do 60 but there pretty much worthless at those speeds...cool but worthless
09-02-2007, 07:47 PM | #30 |
I simply can't imagine an xmod having the mass to provide enough traction to spin tires at that speed and keep itself on the ground. Still call bull****.
09-02-2007, 07:50 PM | #31 |
There is a vid of one on youtube doing 99 km/h (60mph) on a test stand, but as accurately stated by Harley, a Tamiya stationary stand is WORTHLESS in comparison to true ground speed. The stands don't begin to replicate ground resistance, and are pretty much just a fancy way of showing tire RPM in a low resistance scenario. A photo-tach could do the same thing.
09-02-2007, 08:56 PM | #32 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
i would be turning my xmods into a crawler but i busted the center peice's tab that holds the rear end on. anyone got a spare? ill try to get a thread going eventually. |
09-02-2007, 09:08 PM | #33 |
JB weld.
09-02-2007, 09:12 PM | #34 |
I am not saying I haven't wanted to buy one before, I am just saying I don't believe the speed claims. Xmodification did a pretty cool blazer that made we want one again. |
09-03-2007, 08:12 AM | #35 | |
I have another xmod truck titan and blue f150 body nib if any one wants to buy one | |
09-03-2007, 08:42 AM | #36 |
| I hear ya, i have 3 gen 1 xmods, an evo 'stang, and a f 150 with 4wd and lift kit, i have a couple stage 2 nib motors and gears and soem more stuff for them, i juts lost interest on them after i put all the stuff on the f 150 and use the stock motor and gearing and it could barely pull it's weight, so i said enough $ dumped on this stuff, until i saw Xmodifications build, they are really awesome, i might hit up Corey at Rpp for a runner kit or yota truck |
09-03-2007, 02:49 PM | #37 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
09-03-2007, 02:57 PM | #38 |
| it will probably only hit like, 35-40 right now. but thats with stock motor and gearing, pretty soon it will have an atomicmods motor. and I'll try to get some nekkid pics later |
09-03-2007, 02:58 PM | #39 |
| what have you actually changed other han cosmetics like tyres and body height and stuff?
09-03-2007, 03:44 PM | #40 | |
Alloy rear gear box case Alloy dogbones alloy knuckles alloy shafts/outputs radioshack tire upgrade with civic wheels (drag tires for pics, i rarely drive with them on:P) Lithium-Ion batteries (wow huge upgrade) atomicmods v2.2 board (need it to run the liths) a ton of other stuff im forgetting about | |
