10-22-2007, 05:50 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Elizabethtown,KY
| Traxxas Velineon Brushless System
Has anyone used this one? looking to use this for my stock TLT for fun fast ride while I finish my Axial Project. TLT may turn into rock crawler later.. |
10-22-2007, 06:10 PM | #2 |
Quarry Creeper Join Date: Aug 2007 Location: Planet Earth
I dont think the tranny and the gears would hold up to well to that system. I have a Velineon in my Evader and had to upgrade the tranny and differential.
10-22-2007, 06:33 PM | #3 |
really.. I guess MambaMax & 5700 brushless motor combot kit might be too much too? what else I can do to have fast truck with stock tranny |
10-22-2007, 06:51 PM | #4 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
A 55t lathe is too much for the stock stuff. It's not worth the time to even mess with it. Stock tlt diff gears in the axles aren't going to hold up to a fast brushless system either.
10-22-2007, 06:59 PM | #5 | |
like to have some speed and have hard time finding what I want. I will go either brush or brushless and esc. any thought ... | |
10-22-2007, 07:01 PM | #6 |
Just throw a higher voltage in there for some cheap thrills. Not really the right vehicle for it though, you would need open diffs for that power.
10-22-2007, 07:05 PM | #7 |
10-22-2007, 07:06 PM | #8 |
That means the differentials need to be open, and not locked.
10-22-2007, 07:11 PM | #9 |
Even open I think they wont last long.... |
10-22-2007, 07:12 PM | #10 | |
if you think Velineion is killer and Mabma... do you have any thoughts on option that I can make this faster truck? | |
10-22-2007, 07:13 PM | #11 |
35t motor on 3s lipo would be fast. Or just the 55t on 3s.
10-22-2007, 07:14 PM | #12 |
10-22-2007, 07:18 PM | #13 |
10-22-2007, 09:15 PM | #14 |
Pebble Pounder Join Date: Mar 2006 Location: portland
Id do 8 cells on the stock silver can. Or a 19t brushed. But i broke ring / pinions fairly consistently on my scaler with that kind of power till i switched to axial axles. TLT gears just arent that great.
10-23-2007, 07:00 AM | #15 |
| if gears is not up to it ... any upgrades to these parts to make tuffer? I guess this stock diff good for crawler...
10-23-2007, 05:15 PM | #16 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
if you wanna go fast with that tlt your gonna have to beef it up seriously. RCP cvd's and hardened steel pinion, Rc4wd spool, Fatrock aluminum c's, aluminum knucles, bearings. good luck. |
10-23-2007, 06:20 PM | #17 | |
for you as go fast.. what would be the motor and ESC with above upgrades... | |
10-23-2007, 09:18 PM | #18 |
you could definatley run some brushless power through this john would have a better idea of about how high but it could probably handle the velinion if you ran a good tranny. the most id put in the little stocker is a 35T with stock tranny, 27T with an upgraded tranny. |
10-23-2007, 09:27 PM | #19 |
You are really going to have to try it out. If you want a solid axle basher the f350 is your best choice for sure, just keep the diffs open and use a low kv motor on low voltage at first.
10-23-2007, 10:07 PM | #20 |
thanks guys.. I will have to see out come on this.. break the parts or survive.. |
