![]() | #21 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
I am using the Mamba mini, but any brushed ESC will work. I can't find anything any better than the stock motors that isn't MUCH better than the stock motors. The 2.3mm shaft kinda limits options too. |
![]() | #22 |
Let's not be Dave.... ![]() Join Date: May 2006 Location: HONDURAS...ROCK HEAVEN
| ![]() I am confused, so the 454's are only slighlty better? i want to get some slower motors with more grunt on the low end.
![]() | #23 |
The 454's are leaps and bounds above the stock motors. I just couldn't find anything in the middle. Either non-servicable stock motors or cobalts, nothing in between. The 454's are about 2.7x faster than stock, but they can be run on low voltage and still have tons of torque. |
![]() | #24 | |
| ![]() Quote:
![]() Last edited by cartronicshn; 08-20-2008 at 09:46 AM. | |
![]() | #25 | |
Newbie Join Date: Jul 2005 Location: Springville, UT
| ![]() Quote:
It works great now though with the "alternative wiring". | |
![]() | #26 |
Rock Crawler Join Date: Mar 2008 Location: Arizona
Do you think that the 454 would work in the Losi?
![]() | #27 |
![]() | #28 |
Quarry Creeper Join Date: Aug 2007 Location: Lumberton
Looks good JRH!!! ![]() ![]() ![]() |
![]() | #29 |
| ![]() Because they are poser shots. I had already broken the front gear by the time I got sense enough to take pics. Again, the breakage was my fault for having too much power and using it without discretion. Well, since I was being a tool and broke a gear with some aftermarket power I decided to modify the truck a bit whilst it was taken apart. I just took the chassis off and bolted the axles up to a HBZ warthog tuber meant for an AX10. I used spare TLT kit links and emaxx ball ends for new linkages. I am waiting on parts from tower to get it driving again, parts I bought were extra gearsets, a ball bearing kit, extra dogbones, and the 11t pinions. I will be bringing it to the comp in KC for a play rig in the new form. Once I get the electronics installed I will get some more flex from the added weight. This is more of a play rig than a comp rig, as the tuber is heavier than it needs to be for this little build. This puppy will be a wheelie machine now! But I will have to take it easy until the metal replacement parts are ready. I really like this tuber with a short wheelbase. I will put body panels on later. |
![]() | #30 |
Pebble Pounder Join Date: Aug 2008 Location: frederock,maryland
holmes,do you have any vids of your cliff climber in action?I'd love to see one
![]() | #31 |
Not yet, I will try and get one up soon.
![]() | #32 |
Newbie Join Date: Jun 2008 Location: florence
![]() | #33 |
Quarry Creeper Join Date: May 2007 Location: Hilo
What about the reedy 380's?? I think those are rebuildable maybe rewindable. I know when I put 1 in my 18r it actually slowed down. Il'l check tomorrow if the its truely servicable.
![]() | #34 |
I wanna be Dave Join Date: Sep 2004
they never redid the parts manual. the truck actually comes with 11t pinions.
![]() | #35 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
Yeah, but they need like 8t or 9t pinions... JRH, got a source? |
![]() | #36 | |
| ![]() Quote:
I am working on it, I am getting tooling made so my machinist can cut them for both the Berg and CC. | |
![]() | #37 |
Rock Crawler ![]() Join Date: Aug 2005 Location: Illinois
JRH I ran the motors for a while yesterday. WOW! They are sick man. You weren't kidding about how fast they are, and the torque is awesome. I put them in my fully optioned kit so I will bring it along with me to the Nats next week. I will call you later today. J |
![]() | #38 |
| ![]() You may be right I have to check what it is. hehehe You are right!!! ![]() Last edited by rn38; 08-27-2008 at 05:00 PM. |
![]() | #39 |
John, did you get the parts for your truck yet? i would like to hear any more pointers and tips on your setup.
![]() | #40 |
Yep, got them in. I just need to hack a few tubes off the frame so I can put lower shocks on there. Will do after breakfast.
