Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: the greencoast crawler
Old 11-15-2008, 12:16 AM   #1
Default the greencoast crawler
I got my CC about a month ago and its been a slow progress with very limited funds. im still hopping to add some more goodies to this but its very reliabe i havent broken a thing on it and i drive it as hard as i can.
specs:
stock motors(one day to be hh)
LRP AI esc(have a mamba max sent in to castle cuz it was fried)
m3 hammers HPI spike rims narrower
axial high ground clearence links and integy top links
locked rear
hitec 645 mg(one day a JR)
2 1/2 ounces in/on each diff housing
still plastic gears(will get the metal ones when in stock at my LHS)
XTM xcellerator shox in the rear limited 1inch in and 1/2inch out
T4 shox front no limiters and stock coils
flipped steering knuckles side to side to get 1/8inch more groundclearence
8 3700 mah sub-c cell battery pack and one 4200 mah
slammed losi mf2 custome rock clawler body(1 hour with the heat gun)
had to do a little jumbleing for these links to work and have the front paralel wth the ground
front
rear lock out also on both front and rear the screw on the suspension linkage mount b is inverted so the screw head is in the recessed hole reducing hang ups
lots of skid plates everybody loves skid plates. i found that the wheel well cut outs made excelent scale like(as in reptile) skid plates
at full flex just shy of 90 deg
green coast rock crawler friendly keep the plants inside away from the rocks
side view
flex shot with the body
this body will be crisened tommorrow at allred with some of the occrawlers
gigercreeper is offline   Reply With Quote
Old 11-15-2008, 03:03 PM   #2
very nice!
nitrosport963 is offline   Reply With Quote
Old 11-15-2008, 05:45 PM   #3
srcatched it up today at allred park hears a few action shots
i think i need to dail down some of the articulation
Old 11-15-2008, 10:56 PM   #4
good idea looks like a great comp rig though good job man
phase10 is offline   Reply With Quote
Old 11-15-2008, 11:43 PM   #5
not yet still need some upgraded motors and esc the stock motors arnt bad but. they fade hard and fast i bought some e-flight heat sinks cured that problem and they were way cheep i think i spent under 8 bucks
Old 11-16-2008, 10:53 AM   #6
vltchkr's Avatar
Great looking rig!! So did you get the Mamba working or is that the stock electronics? Before I had the mamba in my CC I did the single battery mod and used my lipo, that will certainly liven up the motors.
Andrew
vltchkr is offline   Reply With Quote
Old 11-16-2008, 09:30 PM   #7
not stock LRP AI. the mamba is of to Castle creations along with the money to fix it
Old 11-16-2008, 09:35 PM   #8
wats the single battery mod
Old 11-16-2008, 10:59 PM   #9
dailed out some the suspension heres some pics form hart park
also added springs in the rear and inverted the shocks and move the link forward 1 hole
Old 11-16-2008, 11:12 PM   #10
vltchkr's Avatar
Great looking rig, so what is the wheel base? On the stock ESC, the "b2" positive and negative power the BEC, so use those and you can have just one pack to run. You need to short the B1 wires to get power to the motor.
BTW do you have any more of those East Coast Hydro stickers?
Andrew
Old 11-16-2008, 11:23 PM   #11
12in axel to axel stock width. they are Green Coast Hydro and Green Coast MotherF*****. not east coast. i have tons of both
Old 11-16-2008, 11:32 PM   #12
vltchkr's Avatar
My bad on the mistake, If you have a few of each to spear, I can PM you my Address. I built my shock hoops today I will take pics and add to my thread. i should of looked at your location, I am from San Jose.
Andrew
Old 11-16-2008, 11:50 PM   #13
in nor-cal
Old 11-16-2008, 11:57 PM   #14
vltchkr's Avatar
in nor-cal
Yes, but we will be in so-cal by 2010
Old 11-17-2008, 12:03 AM   #15
thats cool. well not right now its hot and ashy
Old 11-20-2008, 09:02 PM   #16
looks good
D.J.D.H. is offline   Reply With Quote
