Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Help with wiring new esc
Old 07-29-2009, 10:17 AM   #1
Default Help with wiring new esc
Ok so I happened to have a hi tec esc laying around that still works. I wired it as in a Y from the esc wires to go to the front and back motors. Now the front spins foward and the rear spin backwards. Did I wire this wrong?
09xD is offline   Reply With Quote
Old 07-29-2009, 10:31 PM   #2
Sounds like you just need to switch the wires around on the motor that spins in reverse.
fixed13 is offline   Reply With Quote
Old 07-30-2009, 07:13 AM   #3
how do you do that? Or which wires?
Old 07-30-2009, 07:15 AM   #4
Also, would this Losi esc work with a CC set up? Its cheap and probly better than the stock DTX one. Just curious, thanks.
http://cgi.ebay.com/LOSI-LOSB0825-TW...d=p3286.c0.m14
Old 07-30-2009, 07:56 AM   #5
the mini lst dual motor esc is great.... the problem is that the stock motors dont like to run with any torque @7.2-8.4 volts. so unless you find some lower voltage motors its a waste of time (how do i know? i tried it myself! haha) so to solve the problem i ran to the hobby store and had them order me up the lowest Kv rated low voltage motors. they happened to be titan 380's by traxxas. 5000kv. and they are worthless (for a crawler)
i dont think the guys have come up with any low voltage motors other than the holmes dealies. but those are pricey. find an EVX if you can.
brees is offline   Reply With Quote
Old 07-30-2009, 08:24 AM   #6
The ability to run 2 motors isn't the big deal, just about any 1/10 scale ESC can handle 2 smaller motors. The thing, like has been mentioned, is the voltage. Are there any cheap ESC out there that can run 9-12 cells nimh or 3-4cell lipo?
Jamus is offline   Reply With Quote
Old 07-30-2009, 08:57 AM   #7
So is the EVX my best option, or maybe going back to the DTX esc? I also came across the HPI GT dual motor dual battery esc. Priced about the same as the DTX esc but seems to be nicer. Its a 16.8v also I believe. Im kinda torn between the HPI GT and the EVX....I really dont want to go back to the DTX since mine broke at just 2 months. I hope to get an esc that will last longer. Thanks for the help guys!
Old 07-30-2009, 09:37 AM   #8
Get a Pro Boat esc, fully waterproof, no drag brake, no reverse delay, good up to 12 volts i run them in both my scalers.
http://www.horizonhobby.com/Products...ProdID=PRB2314
ScalerLover is offline   Reply With Quote
Old 07-30-2009, 10:30 AM   #9
Is this prewired for dual motors?
Old 07-30-2009, 10:36 AM   #10
No but its easy to make a Y-Harness.
Old 07-30-2009, 01:57 PM   #11
What kind of battery packs are you running? Just a single 6 cell?
Old 07-30-2009, 02:59 PM   #12
Im running 6 cell 7.2v - 9 cell 2/3A 10.8v packs on the Pro Boat until i upgrade to 3s Lipo.
Old 07-30-2009, 03:06 PM   #13
so your running a 6cell and 9 cell? Or just one or the other....just want to make sure I get the info right before I decide to order it....did you run them with a standard style y set up? Did you have any issues with the rear axle spinning in reverse instead of foward? This sounds like it could be a good set up for my scaler.
Old 07-30-2009, 04:31 PM   #14
I'm sure he means 6 or 9 as 6+9=15cell would be much more than the 12V max. That pro-boat esc is tempting but the BEC is sickly, so you'd probably need an external BEC. $40 ESC + $20 BEC and shipping. I think I saw a used EVX in the classified section for $45.
Old 07-30-2009, 04:39 PM   #15
Just one or the other for the batteries, and yes sorry i forgot to mention you DO NEED a BEC as the internal bec on these sucks hunky dorry.
IMO for around 65 bucks between the esc and bec its still a good deal compared to others because you never get the most out of an esc without a bec anyways, and second, the size comparison of this to an EVX is immense.
Old 07-30-2009, 04:42 PM   #16
Also, if your front axles spins forward while pulling on the trigger for forward, and the rear axles spins backwards all you have to do is switch the leads to the rear motor. IE if the motor has a + side marked (most do) and the red positive wire is hooked there and the black negative to the other, then just switch the wires so they will be backwards IE black negative to the + side of the motor and red positive to the other side.
NOTE : only do this to the wires going from the esc to the motors !!! Not to the battery !!!!
Not trying to call anyone stupid... but you sound kinda new to this
Old 07-30-2009, 05:21 PM   #17
LOL yeah still new to the esc thing...Ill have to try and see if I can get this esc to work...might not have to spend anything...but thanks for the info from everyone...I found an evx for about 55 shipped on RCU and if this doesnt work im all over it.
