Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Duratrax Cliff Climber
Thread: tire rub...wheel offsets?
Old 10-18-2009, 01:26 AM   #1
Default tire rub...wheel offsets?
the problem im having is: moved links & shocks to the outside, (to clear banebots 395's) now my proline & 2.2 rovers are rubbing i tried my buddies readcat beadlocks & rover 2.2's, not as much rub but still cant go to full lock. i'm looking for a wheel with less offset as 8 shooters. -offset. any ideas fellas?
73fordhighboy is offline   Reply With Quote
Old 10-18-2009, 10:35 AM   #2
~THE SCALE SHOP~
yep i run the mayhem 7s full offset. they have no inside lip on the inside of the wheel.
STANG KILLA SS is offline   Reply With Quote
Old 10-18-2009, 11:21 AM   #3
I would get a hold of Mayhem Eng.
Mayhem Eng. is offline   Reply With Quote
Old 10-18-2009, 11:49 AM   #4
^^ thanks fellas
Old 10-18-2009, 03:07 PM   #5
any other ideas out there? was gonna try the rc4wd axle extender. i was wanting to stay with a plastic wheel. (cheap) limited (for now) budget:-(
Old 10-18-2009, 07:11 PM   #6
I cut the inner bead off the stock wheels ... they are almost flush with the mounting surface now. I use silicone to glue my tires now so I can still swap and re-use later. Guess I just like the stock wheels.
Rockfrog is offline   Reply With Quote
Old 10-18-2009, 07:15 PM   #7
cut the what? off of where?
Old 10-18-2009, 07:20 PM   #8
as for the wheels i want...wife said to wait. spending too much on my $100 CC. i've only had the thing like a month or so. damn that wife
Old 10-18-2009, 08:57 PM   #9
I joined the Band!
true to that........
TNCrawler is offline   Reply With Quote
Old 10-19-2009, 12:13 PM   #10
I narrowed the wheel from the inside ... removed the entired inner bead (part the tire fits into) and re-glued the outer lip back on ... I have about 1/8" offset now and a narrower wheel.
Old 10-20-2009, 01:27 AM   #11
i found wheels! rc4wd rock rippers have the same offset as a stock bully's aluminum beadlock. i tried my buddies wheels and they cleared all my links lock to lock no rub
