Thread: microswitch for lights questions
Old 03-31-2008, 01:31 PM   #1
Official Cook of the ECC
Scattman's Avatar
Default microswitch for lights questions
Looking to remotely control the lights on my scalers. I want to use microservos and some small switches.
I wil be using my 7 channel Multiplex and have 4 channels left to use for the lights.
Any suggestions or links to switches that would be good for this type of setup.
Is this the best route to go? You can't just control the lights right off the reciever can you?
I have been just plugging in a 9 volt before the runs but I would like to step it up a notch. My radio also does a flashing mode where it moves the servo between points so I am thinking flashers are a must have.
Scattman is offline   Reply With Quote
Old 03-31-2008, 01:43 PM   #2
Might want to check out DimensionEngineering. They have lots of interesting things like the PicoSwitch and lighting-specific bits.
http://www.dimensionengineering.com/PicoSwitch.htm
- Chris
Gimpy00Wang is offline   Reply With Quote
Old 03-31-2008, 01:43 PM   #3
Default scaler remote lights
I know there is a way to control your lights via remote with an open channel on your RX. Get a connector from an old servo and connect your +,- leads from your light setup that would be connecting to the on/off switch and connect them to the +,- on the RX connector. Disco I think this should work for you.
volumeone is offline   Reply With Quote
Old 03-31-2008, 02:04 PM   #4
Ram RC makes some plug in simple RC switch that could be used for turning lights on and off.
www.ramrcandramtrack.com
Thorsteenster is offline   Reply With Quote
Old 03-31-2008, 02:51 PM   #5
Location: Ramstein Air Base Germany ...ya Ive been Ramshafted
Negative!!!! This doesnt work, The lights will always be on! There will not be any on/off control setting it up this way. The +/_ wires on the conector only supply power and the other wire of the three is a signal wire the device like a (servo) uses as imput to know where it should be. The Pico switch is the answer to this if you want lights controled on/off by your radio or you can use micro servo and switch .
CCFBERG is offline   Reply With Quote
Old 03-31-2008, 03:31 PM   #6
You set it up like the D.U.D we used on supers.
I used a Hitec micro servo (hs81mg) and a roller switch from radio shack. I know JP Custom has switchs that will work. Check under D.U.D. in the clod section
drumbeater is offline   Reply With Quote
