| | #1 |
| Rock Crawler Join Date: Aug 2005 Location: Lufkin, Tx
| I do not have time to do search through the tons of post on BEC wiring since I have no power at my house and I am borrowing a friends computer while at there house. I need to wire in my BEC on my steering servo but I want to run the dig servo off of the ESC. I was told I can put a y adapter on channel one and plug in the BEC and the servo on that. But I dont have one of those and I wanting to find another way of doing it. I also would like to do it without cutting off the plug on the end of the BEC so that way I can reprogram it easily without splices a bunch of wires. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
| this is how mine is done, you can wire the steering servo to the ccbec and wire the dig servo to the esc this way also......hope this helps... Definitive wiring diagrams for BECs Rx Servos Motors etc. |
| | #3 |
| Rock Crawler Join Date: Feb 2008 Location: Nebraska
| Here's what you can do. Plug the ESC into the reciever like you normally would (like if you don't have a BEC) Then the ESC powers the receiver and your dig servo (which would also be plugged into the receiver like normal). Next, only connect the signal wire from the steering servo to the receiver. The servo power wires are connected directly to the BEC output. Then the signal wire coming from the BEC is not used. This would have the BEC only powering your steering servo. |
| | #4 |
| I wanna be Dave Join Date: Jun 2005 Location: With my family
| yeah what they said. I knew I was forgetting something. Sorry bout that bud! |
| Thread Tools | |
| Display Modes | |
