Thread: need r2d help
Old 10-13-2008, 04:44 PM   #1
Default need r2d help
today i finished putting together my ax10 with my new r2d tranny. i have novak 55t motor dx3r remote 7 cells with a castle bec. i am using the traxxas 2075 digital servo for the dig, and have burnt up 2 of them trying to get the thing to work. cant understand why it is binding and melting the servos. any help would be great
27cameron is offline   Reply With Quote
Old 10-13-2008, 05:06 PM   #2
Official Cook of the ECC
Scattman's Avatar
Have you adjusted your endpoints? Doesn't sound like it.
Scattman is offline   Reply With Quote
Old 10-13-2008, 07:04 PM   #3
should i adjust the end points to like 50 until i figure it out? and adjust as needed. it felt like it was binding, and then it was too late i didnt even have time to Ajust anything it melted so fast. thanksfor the info.
Old 10-13-2008, 07:20 PM   #4
I would adjust them down to like 10 or 15 and then work up from there.. They don't take long to adjust once you get it started, just be on the safe side and start super low..
HomerJ is offline   Reply With Quote
Old 10-13-2008, 07:33 PM   #5
The way I do it is:
1) Disconnect the servo horn, and make sure the 3rd channel switch is in the middle position
2) Turn everything on, and with channel 3 travel at 100% align the servo horn to the servo.
3) Turn down the travel to 20-30%, and lock down the dig collar on the shaft
4) Work one side (ie 4wd or dig lock) at a time and slowly increase travel to the desired engagement
Simple and always works
bustedcrawler is offline   Reply With Quote
Old 10-13-2008, 07:34 PM   #6
Scattman's Avatar
I would definately start out less than 50. There is very little travel from 4wd to locked.
I would start with the linkage unhooked at first till you get the amount of travel worked out.
Old 10-13-2008, 08:12 PM   #7
i would like to use 4wd, locked out dig, and just disconnect. how do i gets this set up with the 3 pos. switch.
Old 10-13-2008, 09:23 PM   #8
Adjust the linkage to disconnect when in the middle position. Then use the EPA adjustments for locked and 4wd either positions 1 or 3 depending on where your servo reverse is set.
AreCee is offline   Reply With Quote
Old 10-14-2008, 06:18 AM   #9
See my quote below which is ment to get the radio and servo adjust to have a 3 position r2d, with 4wd, fwd (mid position on radio), and dig lock.
It will take a few minutes to go through everything and set it up right. There is no magical way to just blindly adjust the radio to make it work. So, crack open a Dew/Beer/JD bottle/whatever your beverage of choice is, and slowly work the steps and tricks in this thread. Be for you know it, you'll have that R2D set-up like a champ.
Originally Posted by bustedcrawler View Post
The way I do it is:
Old 10-16-2008, 10:32 AM   #10
thanks for the help everyone. got the thing set up and its awesome now just got to get my gearing right.
