11-15-2008, 10:13 AM | #61 |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
That's what's great about the Hyperion chargers. One charger with a built in balancer and just get the four different adapter boards to cover the four different balance taps out there. Jason |
11-15-2008, 10:17 AM | #62 |
Most certainly. I use the hyperion dongle for every pack except TP type. You can use the 4s slot and align any .1" spaced tap to the negative side. Works like a charm. Not the intended use, but saves space in my travel kit. |
11-15-2008, 11:01 AM | #63 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
I still need some different adapters. I am using the Hyperion as my main charger.
11-15-2008, 11:13 AM | #64 |
There are two standards, .1" (2.54mm) and 2mm spacing. If you are clever two adapters will work for every battery under the sun.
11-15-2008, 06:28 PM | #65 |
Quarry Creeper Join Date: Mar 2008 Location: richmond
john....... the charger got here today, looks very nice. i chose well thanks for the prompt service,banana plugs,and xtra stickers. i will talk to you soon about a purchase on one of your handwounds. |
11-15-2008, 10:16 PM | #66 |
No problem! Just poke around a bit. A hint- hit the mode button while charging for extra features.
11-16-2008, 02:18 AM | #67 |
RCC Addict Join Date: Jan 2007 Location: San Jose
12-07-2008, 10:50 PM | #68 | |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
I am in the same boat---getting my first lipo setup.. Read thru this thread and I will be going with the 606I also... So all I need are 4mm banaplugs for the output? | |
12-07-2008, 11:04 PM | #69 |
Rock Stacker Join Date: Oct 2008 Location: SD
Got one of these after going thru this thread, VERY happy so far. Steve |
12-08-2008, 06:18 AM | #70 |
ive had mine goin on 3 weeks now, its a great charger with many features!
12-08-2008, 06:18 AM | #71 | |
We supply supply the battery charge leads and you can even pick what main battery connector you want installed on them. http://www.maxamps.com/products.php?cat=33 Jason | |
12-08-2008, 07:14 AM | #72 |
RCC Addict Join Date: Jan 2005 Location: Germany north
I´m more than happy with my I-charger 106B+ http://www.jun-si.com/EnProductShow.asp?ID=91 |
12-08-2008, 11:26 AM | #73 |
i switched and now have the 606i. very happy with it. balancer too.
12-11-2008, 12:35 AM | #74 |
Just ordered mine from holmes hobbies |
