12-11-2008, 09:16 PM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
| dx6i programing ? and binding issue
I've been using a dx6 since i started in crawling last year, but santa brought me an early present - a dx6i.. I was able to set up the dx6 for mixing with the vf dig but im having trouble with getting the dx6i to bind. Im using the ar6000 rx from the dx6 witch they say will bind with the 6i but no luck. any ideas? Also does anyone have any program input for mixing channels on the 6i. I cant seem to set it like i had the dx6. id liek to mix the gear and flap switches for dig. Thanks for any help |
12-12-2008, 04:05 AM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
It should bind for you? Are you doing it the same way as with the DX6? Put power to the RX with the bind plug installed, While holding the "Trainer" switch pulled back then power up the DX6i and hold till it binds. Your DX6i book should show you how to mix everything. I know I had to dig through it when I set mine up like your doing. If you can't find it in there shoot me a PM and I will walk you through it |
12-12-2008, 06:32 AM | #3 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
With my AR6000 it took almost a minute to bind! I tried a few times and thought it wouldnt but i just kept holding it an it finally did. I am still working on the mixing myself.
12-12-2008, 07:43 AM | #4 | |
