04-17-2009, 08:10 PM | #1 |
Rock Stacker Join Date: Nov 2007 Location: Sacramento
| Dig Servo problem
Hey all, I am having some problems with my dig servo. When I apply throttle, the servo jumps around. I thought the servo was going out and replaced the servo and am having the same problems again with it. I am running a CC BEC set at 6v to the receiver. I do remember reading a thread about metal link ends and the servo arm touching and replaced them with plastic ones, but no luck there. I have moved wires all around to see if it was some electrical interference but that is not the problem either. I have been working on this for about a week now and now luck, please any help would be greatly appreciated. Let me know if I am missing anything, I have searched all over this site and others. AX-10 with RC4WD R2D tranny Mamba Max, CC BEC set at 6V 55T Motor Spektrum DX3R and 3100 receiver Hitec 5955 (steering) Hitec 645 (dig) Thunder Power 2S 2200maH |
04-17-2009, 09:07 PM | #2 |
Rock Crawler Join Date: Feb 2008 Location: Nebraska
I had some issues when I was running the BEC through a Spektrum receiver. I now have the receiver powered by the ESC and the BEC is wired directly to my steering servo. This cured the problem for me.
04-17-2009, 09:20 PM | #3 | |
I wanna be Dave Join Date: Jan 2009 Location: laying low
good luck Definitive wiring diagrams for BECs Rx Servos Motors etc. | |
04-17-2009, 09:51 PM | #4 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
Try setting the frame rate on your radio to 16.5ms. My berg did the same thing till I changed the frame rate. |
04-17-2009, 10:16 PM | #5 |
Ok, so I hooked the dig servo up to a y harness with the BEC, and only the signal wire going into the receiver plus the framerate change and still nothing. The wiring diagram would be the same thing as the Y Harness i believe, except for solder.:-(
04-17-2009, 10:25 PM | #6 | |
where is your ESC power wire at right now?? mines wired just like this.. Last edited by 53 willys; 04-17-2009 at 10:29 PM. | |
04-17-2009, 10:39 PM | #7 |
The ESC power wire is plugged back into the receiver now, while the BEC powers the dig servo (just testing). I did take my old 645 servo that I thought was bad, hooked it up to the receiver and unplugged the one attached to the rig. Here is what I found out, when the servo is close to the motor/tranny it will glitch, but if I take it 10 inches away, the glitch goes away as well. Now this is really confusing because the servo has to be attached to the tranny! ughh |
04-17-2009, 11:33 PM | #8 |
Well, I guess tomorrow I will go to the LHS and pick up some capacitors and see if that helps with the electrical noise. Anyone else had interference with r2d/55t and Spektrum DSM radios. I would expect it from an AM/FM radio, but not this.
04-17-2009, 11:35 PM | #9 |
| Did you try changing the frame rate?
04-17-2009, 11:42 PM | #10 |
04-17-2009, 11:44 PM | #11 |
04-18-2009, 12:29 AM | #12 |
I would say you need Caps on the motor, but I've run Integy motors without them using the DX3R with no issues before, but that was with a plastic Axial tranny. Since the R2D is all metal, it could be compounding the problem.
04-18-2009, 08:04 PM | #13 |
Pebble Pounder Join Date: Aug 2008 Location: the land of entrapment
I am having the same problem,but I have different stuff.I am running a tekin fxr,hh7t motor,dx3.0,cc bec,jr 8711 steering servo,and a hitech dig servo.I am running a dmg dcr chassis,and alot of metal goodies.I moved wires around and the same crap keeps happening. ?????????????????????????????????????????????????? ???????????????????????? |
04-19-2009, 03:18 PM | #14 |
| Fixed!
Ok, so I was down at my LHS and the guy there told me the brushes might be going out in the motor, so I picked up another one and no more problem. I know nothing really about these motors or how to rebuild them, but the dig servo seems to be working correctly now with no more interferance. FINALLY! |
04-20-2009, 09:19 AM | #15 |
Quarry Creeper Join Date: Mar 2008 Location: richmond
| same here , my rig would only work with the bec running only my steering. my esc handles everything else
