Thread: Traxxas summit servo control
Old 08-07-2009, 06:03 AM   #1
Default Traxxas summit servo control
Hi.
I have the venom creeper and im wondering if the same system used to controll the 2 locking diffs on one channel from the summit would work.
The only thing is im not actaully sure how it works..i understand you can lock all unlock all or just lock the front.
Is it some kind of servo mixer?
Craig
craigrobbo is offline   Reply With Quote
Old 08-07-2009, 07:14 AM   #2
The Summit controller is 4 channel giving you throttle, steering, Diff lock and gear change. As far as I know both diffs on the Summit are either locked or open on the standard set-up.
That said there's not reason you could have the front diff on the 3rd channel and the rear on the 4th for your Creeper.
Tupers is offline   Reply With Quote
Old 08-07-2009, 07:23 AM   #3
On the lookout for Rocks
constantmotion's Avatar
Not sure if the Venom has front and rear lock diffs.
I don't see why the Differential Locking Controller wouldn't work. You will just have to have a 3pos switch to run it for both servos.
constantmotion is offline   Reply With Quote
Old 08-07-2009, 07:57 AM   #4
HI guys thanks
Firstly the venom does have front and rear diffs (lockable) i got one in front of me
Second, according to the traxxas site, the options on just a single channel are 'both locked, both unloicked, front locked rear open' it uses 2 seperate servos (one front one back) but i have no idea how you can controll the 2 fron one channel...is it a mixer?
EDIT: also Tuper im using a 3ch radio and ant to cntroll the 2 servos independantly, maybe a programmer or mixer.
If its not is there any mixers out there that will allow me to?
Craig
Old 08-07-2009, 11:20 AM   #5
Are you using the Venom remote locking kits or making your own?
PunkRC might make something that'll allow you to run 2 servos independently from one channel. I use a 6ch radio, so I haven't really explored the 3ch options.
Something to be aware of - whatever the solution, you'll need something that has adjustable endpoints. You need to set the linkage spot-on, or you'll burn out the servos. It'll be a real pain trying to get it right with fixed travel.
I made my own on-axle servo mounts and linkages, using Hitec HS-55 servos and airplane fittings. Works much smoother than the Venom kit. Link here:Diff locks - this seems to work real smooth
clockworks is offline   Reply With Quote
Old 08-07-2009, 11:47 AM   #6
Thanks clockwork, i did see yours. looks awsum. i was thinking of somthing alog the lines of that and i was hoping i could get a controller taht will allow me to se the EPA's and adjustments on it.
I would get a 6ch controller but the only ones i can find are all stick type
i like pistol
Craig
Old 08-07-2009, 12:30 PM   #7
Traxxas summit has one servo for one diff - and both servos are indeed controlled by one channel with splitter some sort - as the TX has 3 position switch: 1: open diff, 2: front locked, 3: all diffs locked.
So short aswer would be that yes you can use summit splitter in venom lockers.
badgravity is offline   Reply With Quote
Old 08-07-2009, 12:57 PM   #8
i like pistol
Craig
You can make your own 6ch pistol controller as well - several threads on here.
Old 08-08-2009, 10:02 AM   #9
A little bit on the complicated side for me that is.
LOL
Craig
Old 04-14-2011, 02:05 PM   #10
hey guys same thing you where talking about with the t lock but does anyone no which positions on the traxxas controler work front and rear and free i think mine are messed up
cekm2010 is offline   Reply With Quote
