11-23-2005, 11:36 PM | #41 | |
Newbie Join Date: Nov 2005 Location: toledo
11-23-2005, 11:44 PM | #42 |
similar performance to your pullers, sorry. the cobalt 15 is a 10 turn, but the shaft size is 3/16th and the can is unsealed. |
11-23-2005, 11:48 PM | #43 |
Check these out. Great prices and salarium magnets! Definatly worth testing. http://www.maxxprod.com/mpi/mpi-26a.html |
11-23-2005, 11:49 PM | #44 |
I'm starting to REALLY like the sounds of these motors. $100 a pop is alot but if they truely pull I may get a couple. RC JEDI,could you do a simple test? Hook up a 55t or any common motor and then try one of these. Hook to umm.....maybe an 8" block on the shop floor or something and see which pulls better. Make it a GOOD test,nothing like which one will pull my kitty cat sitting on my skateboard,something that will truely see what the capability of these pullmasters are. If the common motor you use won't pull,lighten the load till it does. If the pullmaster pulls,increase the load till it won't. You see what I'm saying? Having numbers and such to go by is great and all but having a physical test is what I'd like to see. Also,see what difference you get with run times,same truck,same everything,just swap out motors. Runtime is another huge factor for me. I want infinite runtimes with enough torque to pull 2 12" blocks up my very steep gravel driveway |
11-23-2005, 11:56 PM | #45 |
Samarium magnets I meant lol. On the site they have a cobalt that is doing 1742 rpm per volt. Must be close tho the pullers I have.
11-24-2005, 12:05 AM | #46 |
Raptor man, LOL that would be a good test but.......... these pulmasters were desighned for truck pulling comp and untuchable in pulling. They will kill a clod axle and gears before stopping and or just spin the tires if not weighted down. I remeber the pullers back in the day had to usually get the hardened steel clod gear set when pulling weight. There was even an artical in an old rc car action where the guy put a pair of these motors in his clod with hardened steel gears and alot of weight and pulled his "full size jeep" in nutral. Cant remember how far though. Maybee not to good for the kitty cat on the skate board. |
11-24-2005, 12:12 AM | #47 |
ill bet your pullers are 1500 rpm/volt. As for the MPI motors, you get what you pay for. Im trying to find how many poles they are.
11-24-2005, 12:18 AM | #48 |
Yeah but the 05 MPI motors are 99.00 just like the astro's. So get what ya pay for might be a good question lol.
11-24-2005, 12:21 AM | #49 |
the mpi brushless http://www.maxxprod.com/pdf/HC3516-1130.pdf is $81 and just as powerful.
11-24-2005, 12:24 AM | #50 | |
i was looking at a cheaper mpi by mistake I wonder if the brushes and brush hood is as nice as the astro's | |
11-24-2005, 12:25 AM | #51 | |
Well see,thats the problem,they are using Clod axles. Use something thats got at least a shade of strength to it | |
11-24-2005, 12:30 AM | #52 |
Well at the top of the page I posted there were pics of that actual motors in question. They arent like the astro's thats for sure. Raptorman dare I ask what axles you are using that are stronger than clods? |
11-24-2005, 01:18 AM | #53 | |
Until my in laws puppy chewed my housings all to crap I was running Twin Force axles. From the abuse I gave them,I KNOW they are up for the task. I'll be running X Factor axles temp. till I get me some new housings made up for my Twin diffs. I know the X Factor axle are also a very strong set up as well. Heck,I'd probly run Nylint diffs before I'd run Clod diffs | |
11-24-2005, 01:42 AM | #54 |
lol! easy there on the clod axles |
11-24-2005, 01:47 AM | #55 |
And I bet if they were clod axles that puppy would have broke a tooth lmao
11-24-2005, 01:51 AM | #56 |
You gotta take it easy on them or they'll break sorry,couldn't resist |
11-24-2005, 11:10 AM | #57 |
thats actually why i sold my clod axles. they are too fragile for me, especially after using twin axles.
11-25-2005, 01:30 PM | #58 | |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
Good find ! I was on the Integy site last week, and I did not see them. I think other companies will have a hard time matching the $19.99 price Got a pair of 35's heading my way! | |
12-02-2005, 03:43 PM | #59 |
RC Jedi,have you had time to test these motors? Or were you going to? I've got the cash to buy a couple but would like to see a test before I buy. Thanks |
12-04-2005, 02:07 AM | #60 |
I have not got a chance to test these cause of things goin on. But I will soon and then Ill write up a full report for ya. I do know from past expierience though that these motors have a ton of torque and last a long time on a charge. Id say they definatly would be ideal for crawling with a gear reduction cause they will spin some rpms. but anyhow I will say that if you do get them its definatly not a waste of money cause they are very high quality motors and hold theyre value unlike other rc electronics.
