09-27-2009, 12:39 AM | #21 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
| im Darrin, i found a 65..probaly not what your looking for speed wise but if your in a bind..if your running a bec you canm probaly do 3s if you have a 3s pack..good luck tommorow |
09-27-2009, 12:48 AM | #22 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
| The Rooster he has is only rated for a 2s Li-Po daddy-0! 3s will void the warranty and could fry it!
09-27-2009, 01:09 AM | #23 |
Quarry Creeper Join Date: May 2009 Location: Chilliwack, B.C. Canada
i actually have a 55 spare since i decided to switch to my 35t
09-27-2009, 01:19 AM | #24 |
09-27-2009, 01:31 AM | #25 |
09-27-2009, 02:01 AM | #26 |
| Uh, I don't know...? I mean it's not like he would be running a 32P Spur on it before? I would hope your right though. If he was running a 48t Spur it wouldn't climb at all! If he went to a 16t Pinion and had a 85 or 87t Spur his final drive would be 40.87 and 44.62. So if he does have a 48t Spur with a 16t Pinion he's looking at a 3:1 primary gear ratio! Stock Axial #'s are...... Primary Gear Ratio: 6.2:1 Transmission Ratio: 2.6:1 Axle Ratio: 2.9:1 Final Drive Ratio: 46.7:1 So if he did have a 48t Spur that would throw things WAY OFF! 22.6:1 Final Drive |
09-27-2009, 02:03 AM | #27 |
09-27-2009, 02:07 AM | #28 | |
"If using Ni-Cd or Ni-MH batteries, NEVER use fewer than 4 or more than 7 cells (4.8-8.4VDC, 1.2VDC/cell) in the vehicle’s main battery pack. If using Li-Po batteries, ONLY use a 2-cell pack for the vehicle’s main battery & be sure to use Profile 2 with the built-in Li-Po cut-off." Last edited by TattooKenny; 09-27-2009 at 02:10 AM. | |
09-27-2009, 08:15 AM | #29 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
09-27-2009, 09:18 PM | #30 |
thanks for eceryones help! I ended up getting a motor from Jason. The problem was in the motor its self. Must have screwed up in the winding? But at least I now have a motor and now can fix the one I screwed up on. |
09-27-2009, 09:21 PM | #31 |
glad i could help. see you at the next comp |
09-27-2009, 09:25 PM | #32 |
09-27-2009, 09:28 PM | #33 |
Rock Crawler Join Date: Aug 2008 Location: maple ridge
you beat martha!!! Daddy-O! |
09-27-2009, 09:29 PM | #34 |
which one is martha?
09-27-2009, 09:38 PM | #35 |
Joe Miller. AKA Miller AKA Martha |
09-27-2009, 09:42 PM | #36 |
09-27-2009, 10:05 PM | #37 | |
thanx | |
09-28-2009, 01:57 AM | #38 | |
" A MUST USE setting for 4 cell (14.8v) Lithium Polymer packs. You will irreversibly damage your packs using a lower cutoff voltage!" But what your saying is if I use a BEC on my Mamba Max I can run a 5s Li-Po pack? I don't think so. But if you can show me where this is said by any of the manufactures I will say I am sorry;) | |
09-28-2009, 11:16 AM | #39 |
