09-26-2009, 10:43 PM | #1 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
| got comp tomorrow morning and I can't get rooster crawler to reset,please help asap
Problem....I hand wound my 55turn integy motor the other day to a bouble wrap 40turn. LOve it! but the problem is I now have no or some drag drake. I have a rooster crawler, TQ3. I CAN'T SEEM TO EVEN GET IT TO MOVE. I PLUG IN BATTERY AND RED LIGHT IS KINDA FLICKERING SLIGHTLY. I CAN ONLY CHANGE SETTING FROM LIPO TO OTHER BATTERY. I NEED HELP ASAP!!!!! please and thanks, |
09-26-2009, 10:49 PM | #2 |
I turn on remote, hold esc reset button down turn on battery...right? Then when red light comes on you release and full trottle till goes solid green then full reserve till it blinks green and the neutral. then is will go solid red telling you it has been set properly....right My problem is when i turn battery power on and am holding reset button done, red light comes on i release.....i continue to do full trottle but I could do full trottle for like 5mins and it will not change to solid green....????? wtf! |
09-26-2009, 10:53 PM | #3 |
Quarry Creeper Join Date: May 2009 Location: Chilliwack, B.C. Canada
are you going to the comp at ioco in qoquitlam, if so i have an extra motor i can lend you, i have a 35t and a 55t, the spare all depends on what motor i decide to use tomorrow.
09-26-2009, 10:54 PM | #4 |
whoops looks like i read your post wrong, i don't have a spare esc sorry.
09-26-2009, 10:54 PM | #5 |
ya I'm going.... but why a motor??? is it not the esc that controlls the drag brake? |
09-26-2009, 10:56 PM | #6 |
oh and I just installed two new servos(one for front steer and other for dig) also just got a BECs installed. Incase that matters to anyone???
09-26-2009, 10:58 PM | #7 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
yes the ESC does control the drag brake...Not sure this popped in my head, but unplug the motor and try it...don't even know if that will work...ohh is the battery charged?
09-26-2009, 10:59 PM | #8 |
fully charged Lipo 5 mins ago and brand new batts in remote 2mins ago.
09-26-2009, 11:02 PM | #9 |
wish i had my spare rooster crawler now i would have given it to you tomorrow.
09-26-2009, 11:03 PM | #10 |
thanks buddy. whats your name? mines tyler aka lil lucifer. See ya there. But I need to figure this out asap! |
09-26-2009, 11:05 PM | #11 |
im jason, can you run it the way it is now? if you can and can't get it figured out by the comp tomorrow you can borrow my extra motor and see if that helps your drag brake issue. |
09-26-2009, 11:09 PM | #12 |
nope! I ran it for a day with all the new shit(but with little or no drag break). I went to reset it 20mins ago and now I have nothing....no steering, no dig, no forwards/backwards....red light just stays on the rooster??
09-26-2009, 11:20 PM | #13 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
When you hooked up your BEC did you unplug the red power wire from the ESC? Also check and make sure you have the ESC plugged into the RX the right way(Pos+Pos, Neg+Neg, Sig+Sig.) But again, your red wire from the ESC should be unplugged!!!! Are you running a Li-Po? Is it charged all the way?
09-26-2009, 11:33 PM | #14 |
Newbie Join Date: Jun 2009 Location: right there
i dunno if this applys to the rooster but i run the Havok and mine did the same thing and i called them about it and if it a older ESC you may need to send it back to them for a software update, thats what they told me, i sent it to them and got it back and havent had any problem out of it, the best thing is they covered shiping and didnt charge me a dime, so it was free
09-26-2009, 11:34 PM | #15 |
the BECs is a homemade one from a guy up here in canada. Works Awesome! and is not the problem cause it wrked fine hour ago. It was a plug and play kit. The wire to the rooster crawler were backwards...so at least now it moves and drives. BUt still have no drag break????? |
09-26-2009, 11:38 PM | #16 |
I got the rooster working now. the light goes from red to full green to binking green to full red...... but still I have no drag break? if i turn up the trottle trim it just wants to drive forwards.... would a hand wound motor screw things up like this? |
09-27-2009, 12:00 AM | #17 |
oh and I went up to a 48P pinion 16T on the motor. is it suppose to be full green green when going forwards and blinking green in reverse? If not how do you reverse it? swap motor wires? |
09-27-2009, 12:16 AM | #18 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
glad you got it working..the motor plays a big part in your dragbake, i,ll try to remember to bring an extra mtr..the 35 that kernel offered would be great, i might have a 55 kicking around..i,m sure if your having problems tommorow , someone can figure it out |
09-27-2009, 12:24 AM | #19 |
thanks bro! both of you bring your motors and i'll bring some cash if it works for me. I love the little extra wheel speed but the no drag break sucks ass. what is your name? thanks 4 everyones help. |
09-27-2009, 12:26 AM | #20 |
