11-25-2009, 10:26 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: land of 10,000 collapsing bridges (MN)lol
| ~~another lipo question~~
ok im thinking of getting a 5000mAh 7.4V 15C LIPO li-po Battery but all the crawler guys i see have one with a higher C rate like 20C or 25C can anyone help me with understanding this and will it work my ESC is 60amp if that helps at all i dont know.:?
11-25-2009, 10:34 PM | #2 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
15c will work with a 5000mah batt. No one I know runs anywere near that big a batt in their crawler. 1500mah is plenty enough for 45min+ running most the time. I use about 200mah+ per 5min on course. The smaller the batt the more c ya need.
11-25-2009, 11:29 PM | #3 |
thanks but i still dont get the 15C 25C thing????what is it
11-26-2009, 12:20 AM | #4 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
c rating is the batteries safe discharge rate. the discharge amperage is a function of c rating and capacity. discharge rate= c rating X capacity in amps using a 2000 20c pack for example, that would be 2.0amp hours X20 = 40 amps. or better yet, 5.0 ah (5000mah) X 15c = 75 amps. now as far as discharge rate of the battery goes, the higher the better, however you get to a point were more is useless. with a crawler you dont need much, lots of people run 1350mah 25c packs (33.75 amps discharge) with no issues. runtime and size are bigger things to worry about with a crawler, but keeping c rating in mind is impotant. i just set my friends truck up for some 1800mah 30c lipos, plenty of discharge rate and gets 45 minutes on a pack. |
11-26-2009, 12:27 AM | #5 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Its the amperage discharge, the first number is constant and the second number is the burst amperage. I think a 7t puller(pull's high amperage) needs 30c battery. I'm running a 1350ma 25c battery 3s(3cells 11.1v) each cell is 3.7 volts. I ran 3 cousres in a comp. I have a Tekin FX R and a 45t motor. Each course was 7min long and had 700ma left. Hope that helps.
11-26-2009, 01:53 PM | #6 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
The C rating is a disharge rating. The higher the C, The more current can be pulled from the pack.
12-02-2009, 07:58 PM | #7 |
one more question what if i wire 2 batteries in series to double run time will the c rating double??????
12-02-2009, 08:18 PM | #8 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
I found this on Youtube, it kinda makes it easy-ish to understand http://www.youtube.com/watch?v=_J9qCyN7urk |
12-02-2009, 09:24 PM | #9 |
Rock Stacker Join Date: Jan 2009 Location: california
12-03-2009, 12:16 AM | #10 |
you never change the c rating, thats something thats built into the cells. a 20c pack is always 20c. when you wire in parallel you do double the amount of amps you can pull from it. using 2000mah 20c 7.4 volt for an example in series- 2000mah, 20c 14.8 volts- safe to pull 40 amps parallel- 4000mah, 20c, 7.4 volts- safe to pull 80 amps c rating is fixed, max discharge rate is C x mah /1000 |
