05-21-2010, 01:46 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: Albuquerque
| ESC problem?
I've had my LCC for about a month and I'm having stall problems that I can't figure out. It happens when I get one of the tires into a bit of a bind but nothing the rig should have any problem with. Everything just quits, sometimes it last for a few seconds and things seem to reset and othertimes I need to shut everything down and bring it back up again. I'm thinking it might be the ESC (Castle Sidewinder)...any thoughts?
01-04-2011, 03:32 PM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Sounds like you should build your own. |
01-04-2011, 03:46 PM | #3 |
Your funnel's too small |
01-04-2011, 05:06 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Oregon
"ESC's are nothing more than electronically controlled resistors...and they're far less complex than you've been lead to believe". It should be pretty easy for you to figure out. |
01-04-2011, 05:28 PM | #5 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
Well, based on your attitude in the "Funnel" post I'd say you deserve the previous comments..... As for your issue, you need an external BEC. It allows constant voltage to your servo and receiver so the ESC won't bog down while trying to do too much at once. Get the Castle Creations 10 amp version, it's more than adequate for a crawler. If you already have a BEC installed (the internal ones in ESCs are crap) then I don't know..... |
01-04-2011, 06:44 PM | #6 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
You should switch over to a mechanical speed control they are the shizzy. But in all seriousness sounds like you need to install a bec as you are getting voltage spikes and shutting down your receiver. But im sure you already know this with your mass knowledge of electronics
01-04-2011, 07:01 PM | #7 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
I love this place. |
01-04-2011, 07:08 PM | #8 |
Pebble Pounder Join Date: Oct 2010 Location: Rapid City
My lnc was doing about the same thing My rear axle needed to be torn down and regreased. It has a few bushings in it , if they arnt lubed will cause friction and ur crawler will bind on hills and not move.
01-04-2011, 11:09 PM | #10 |
Quarry Creeper Join Date: Sep 2008 Location: Rogue River
I still use a Rheostat.
01-04-2011, 11:09 PM | #11 | |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
01-05-2011, 01:51 AM | #12 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| lol
LOL u guys are to funny.But i agree on the ebec .i hat the same prob with a rooster crawler and the ccbec solved the problem.If thets not it try wickapedia.
01-05-2011, 03:14 AM | #13 |
01-05-2011, 11:10 AM | #14 |
| um
Ok i looked up the definiton of an idiot and it said to refer to the post on rcc under rooktakesqueen .LOL
01-05-2011, 09:57 PM | #15 |
Hahahahaha!!!!!!!!
