01-23-2011, 01:38 PM | #1 |
Rock Crawler Join Date: Mar 2006 Location: Up North
| Tech help turnigy 4x6s charger...
JUST GOT THE TURNIGY 4X6S CHARGER THAT DOES UP TO 4 PACKS AT ONCE..I THINK IT HAS 50W PER PORT...MY POWER SUPPLY DOES 350W 14V 25A ... Can i charge 4x4S 5000mAh LIPOS at 5a or will my house burn down? THERE WAS NO MANUAL INCLUDED.... IM SO CONFUSED RIGHT NOW WITH ALL THESE AMPS AND VOLTS ,WATTS etc. here is a link http://www.hobbyking.com/hobbyking/s...dProduct=11170 thanks |
01-23-2011, 01:46 PM | #2 | |
Quarry Creeper Join Date: Oct 2006 Location: kansas city
| Quote:
I think you are going to find it will not let you charge 4 batts at 5 amps each. It says 6 amp per port but that doesn't mean all at once. Go ahead and hook it up with your batts and it will limit the charge rate I think. Chargers usually have a limit built in to the software. Let us know how it does OK? Randy | |
01-23-2011, 01:49 PM | #3 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
The manual's there under the parts discription. Click on the files tab then on manual to get it. It's a pdf file. http://www.hobbyking.com/hobbyking/s...3X98688X54.pdf |
01-23-2011, 03:04 PM | #4 | |
| Quote:
Awesome....gonna read through this....thanks | |
01-23-2011, 03:05 PM | #5 |
Newbie Join Date: May 2008 Location: tallahassee
I think you should be fine. You are under the rated specs for the supply. The supply probably has some kind of protection built in.
01-23-2011, 03:11 PM | #6 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
here ya go. It employs the circuit that features four totally independent but identical power outputs which are powered 50 watts each. Total powers are 200 watts. As a result , it can charge or discharge up to 4 x 15 cells of NiCd/NiMH or 4 x 6 series of Lithium batteries simultaneously, and maximum current of 6.0A. Furthermore the cooling system is so efficient that can hold such a power without any trouble of running the CPU or the operating program. |
01-23-2011, 03:17 PM | #7 | |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
| Quote:
You'll be Ok, It'll warn you if it can't do it | |
01-23-2011, 03:25 PM | #8 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
I have one similar to it, it will simply adjust the amp down to about 3.2 amp charge rate. 2s is the only one where can use the full 6 amps.
