Thread: Removing On/Off Switch from ESC
Old 01-25-2011, 06:16 PM   #1
Default Removing On/Off Switch from ESC
Do you simply cut off the switch or is there more to it? Thanks
armycrawler101st is offline   Reply With Quote
Old 01-25-2011, 06:25 PM   #2
and solder the red and black wires together, cover in shrink tube when done.
lsone is offline   Reply With Quote
Old 01-25-2011, 07:29 PM   #3
....or you can pop the case off and follow the wires to the board and solder it there.
Manning is offline   Reply With Quote
Old 01-25-2011, 07:59 PM   #4
at the risk of sounding ignorant, what benefit does this accomplish? other than not flipping a switch.
76 warlock is offline   Reply With Quote
Old 01-25-2011, 08:02 PM   #5
less wires to mess with. And the weight savings of 0.002oz or whatever the switch weighs.
Szczerba is offline   Reply With Quote
Old 01-25-2011, 08:30 PM   #6
Suck it up!
Duuuuuuuude's Avatar
FYI: they weigh 0.0021oz.
Duuuuuuuude is offline   Reply With Quote
Old 01-25-2011, 08:43 PM   #7
Plus you will never switch off your speed controller and forget to un plug your battery and run it down. With no switch you have to un plug your lipo when your done playing.
Aggie01 is offline   Reply With Quote
Old 01-25-2011, 08:47 PM   #8
yeah, if you have a BEC you need to unplug anyways.
T3rry is offline   Reply With Quote
Old 01-27-2011, 02:36 AM   #9
I have had mine turn off alot while racing. just fyi
groundhog69 is offline   Reply With Quote
Old 01-27-2011, 03:12 AM   #10
Switches are a PIA in any RC except for maybe some airplane fuselage..Plug and unplug battery for power on/off.One less thing to mess you up..Simple
xv-townboy is offline   Reply With Quote
