04-14-2011, 07:35 PM | #1 |
Rock Crawler Join Date: Sep 2009 Location: Temecula Ca
| 3 Channel toggle switch Wire digram needed
OK I have a Futaba 3 channel with just a 2 way switch I'm unsure on how to wire the toggle switch I'm guessing the toggle switch i have has 3 prongs on it so it would be red on1. 2 leave alone and 3 on black. the 3rd channel 2 way switch has 6 prongs, so i just need a wire digram to figure it out thanks oh yea its for winch controll I looked on the search and seen the spectrum channel one but was kinda lost on it thanks. |
04-14-2011, 08:18 PM | #2 |
Ummm...which Futaba 3 channel? There are several. As to "3 prongs" vs. "6 prongs" usually means, the 1st one is a "single pole double throw" vs. the 2nd one is a "double pole double throw". Basically the 2nd switch type is 2 of the 1st one. Generally, the center prong is "common" and then you "switch" to either of the outer prongs. |
04-14-2011, 08:24 PM | #3 |
I have the Futaba 3PM
04-14-2011, 09:38 PM | #4 |
| hmm
I cant seem to figure it out maybe some 1 could make me a digram on how to do it for dummies |
04-14-2011, 09:54 PM | #5 |
The power wire should go to the middle prong. The other 2 wires need to go to the outer prongs. Beyond that, maybe LosiKid can help out. |
04-14-2011, 10:14 PM | #6 | |
Can you post a picture of how the current switch is wired | |
04-14-2011, 10:24 PM | #7 |
Just did some searching, and yes it is possible. I searched 3pm switch mod I'll be reading through a few threads to see if i can make since of how this works, i'll try and let you know what i find |
04-14-2011, 10:31 PM | #8 |
Unless you want a 3way this thread ought to get you up and going 3PM 3-speed Shift possibility If you want a 3 way theres a few other threads i(or you) can read. LMK if you want a 3way |
04-14-2011, 11:03 PM | #9 |
| Cool thank's Im trying to have the middel toggle off I thought so the winch dosnt keep running.
04-14-2011, 11:31 PM | #10 | |
When i get some time i'll try and see if i can locate a toggle that will give you a 3way. Or if you don't want to mod your radio, i sell adapters that will convert 2 pos signals from a radio into 3 position on the rx side. IF you already have a winch controller. If you don't have a winch controller heyok sells a 2 pos winch controller. | |
04-14-2011, 11:36 PM | #11 |
| unsure if this would work for me
Ok I found this post but Im unsure if this would work for me http://www.rccrawler.com/forum/electronics/209479-futaba-3pm-modded-3-position-switch.html#post2596004 |
04-14-2011, 11:38 PM | #12 | |
04-14-2011, 11:52 PM | #13 |
Thnks for your help
04-15-2011, 07:18 AM | #14 |
Is this the switch you are looking for? Single Pole, Double Throw, Center Off http://www.rpelectronics.com/451-303...on-off-on.html |
04-15-2011, 08:46 AM | #15 | |
04-15-2011, 04:38 PM | #16 |
| +1, from the description it appears to be more of a "staged" switch. Each "toggle" adds in another circuit......I may be incorrect though..... |
04-16-2011, 12:14 AM | #17 |
I have the swich Im just looking to fiure out how to shut the 3rd channel off I have forward and revers only on the winch I thoght I could have 1 on, 2 off, 3 on, but it just stays on im looking for a way to turn it off. |
04-16-2011, 08:12 AM | #18 | |
Winch Controller for Radio with 2 Position Third Channel | |
04-16-2011, 11:05 AM | #19 |
| Here Monday when I get off my phone I'll sit down and try to figure out how to do this, if possible.
04-16-2011, 12:19 PM | #20 | |
