05-01-2011, 05:00 PM | #1 |
Newbie Join Date: Jan 2011 Location: lavalette ,WV
| a good motor
Well i have come to the conclusion that my brushed 27t axial motor is about ready to go. It was good while it lasted lol. What would be a good motor thats in a 16 year olds price range that would do good with the xl-5 esc ? Im wanting to have a little speed and then be able to crawl . btw my motor is sluggish now it goes fast and then slow then fast again.
05-02-2011, 12:39 PM | #2 |
Comp rig (MOA or shaftie), scaler, fun run in backyard? What battery size are you running (6 cell NiMH, 3S LiPO)? Chances are a good cleaning of your motor, oil the bushings/bearings and new brushes are all that is needed. BTW, what state do you live in? I know of a town like yours in NJ. |
05-02-2011, 12:50 PM | #3 |
I am guessing he has a RTC AX10....if that is true, then there are plenty of excellent options. Personally, I'd go with a good 35T Handwound motor.....and Brood Racing can certainly suit your needs! Team br00d Crawler Motors and Batteries.... |
05-02-2011, 02:41 PM | #4 |
i live in WV. my battery is a speedpack 5100mAh 7.2 6-cell Ni-MH and what is the best way to clean it and what to clean it with. and this is my truck looks like my 1:1 i also broke the front drive shaft Friday and went to the LHS and ordered new stock drive shafts as soon as i can get the money i am going to make bumpers and buy a winch and rc4x4 steel rims and new tires and upgrade the links to aluminum as soon as the plastic parts break lol im cheep Last edited by rock-gobbler 77; 05-02-2011 at 03:02 PM. |
05-02-2011, 03:24 PM | #5 |
Quarry Creeper Join Date: Dec 2009 Location: Honolulu
For a replacement motor, a Tamiya "silver can" 27t is good for $20. Nothing wrong with being young and having limited funds. Like stated earlier, a good cleaning and oiling might bring the old motor back to life. For my cheap motors I just connect a "AA" battery to the motor and dip in in a cup of water for 15-20 seconds then oil the bushings/bearings. |
05-02-2011, 03:28 PM | #6 | |
05-02-2011, 06:38 PM | #7 |
An electric motor specific is best, but "3 in 1" or a light motor oil (like a 30wt) will work. Something is ALWAYS better than nothing. You could use water or a sprayable electrical cleaner to clean the motor. Use a pinion gear (attached) to spin the motor while cleaning it out. |
05-02-2011, 06:42 PM | #8 |
i'd suggest a Holmes Hobbies tourqe master 35t, AWESOME MOTOR. i run a 30t custom wound in my scx-10 and its great! has loads of tourqe and good top end, all on a 17 year old's budget!
05-02-2011, 07:07 PM | #9 |
| i looked at the picture of the motor and does it require soldering or anything? might get that one
05-02-2011, 07:14 PM | #10 |
| yes, but you can garb a cheap soldering iron and solder from walmart for less than $10 (and you'll use it a lot in this hobby), as well as soldering is super simple to do! just pre heat and pre-tin your meal part on the motor, then pre-tin your wire/ plug then just melt them together and take off your iron and let it cool! takes longer for the iron to heat up than anything else! |
05-02-2011, 07:17 PM | #11 |
just ordered it lol thanks all now just to get my drive shaft in lol |
