Thread: Re-purposing my Tekin RS
Old 05-23-2011, 02:05 PM   #1
Default Re-purposing my Tekin RS
I was just wondering if anyone had done this or might see an issue with what I want to try. I have searched and searched and cant find an instance of anyone doing this.
I am building an XR10 and have already purchased a Punk Dig. I was going to purchase a Tekin FXR when it occurred to me that I have a Tekin RS already laying around. I know they will do brushed motors (I already have a hot wire) Will it push two 35t brushed motors through a punk dig ok? I know it says it has a 10 turn brushed limit when using forward/reverse function but I wasn't sure how much more load the other motor would put on it. Has anyone done this?
Thanks in advance
-Aaron
ev0l is offline   Reply With Quote
Old 05-23-2011, 02:37 PM   #2
i don't know about the punk dig but when you run 2 motors in parallel they draw the same current as one motor with half the winds so two 35turn motors would draw the same as 1 with about 17.5turns hope this helps
muddawg is offline   Reply With Quote
Old 05-23-2011, 02:40 PM   #3
I've tried running a brushed motor w/ my Rs Pro. I had issue's, one of them was no instant reverse. I contacted Tekin about it, they have been working on a Hotwire fix for it
Sneed is offline   Reply With Quote
Old 05-23-2011, 05:44 PM   #4
This isn't correct..........in most cases you are safe, but its a good way to fry a speed control. 35t motors produce about 90 watts each or so on turbodyno......a 17t will produce about 195....so your safe, however.......a good 19t handwound makes 170+........so, I should be able to run 2 if a speed control is 9t capable right? Hardly......most 9t motors will produce around 300 watts.....your speed controls will go boom....my advice, always email and ask....
A RS is a very capable speed control. It will work fine in your crawler, as it has no power handling limits that I am aware of. The only reason we don't see any RS or RS pros really in crawling is cost and size..........they are HUGE compared to a FXR....but the cost is the big one. I put my RS Pros in my crawler, they worked well, but the weight and size made them impractical so I swapped them out for my fxrs.
Later EddieO
EddieO is offline   Reply With Quote
Old 05-23-2011, 08:01 PM   #5
It "can" be done but honestly the FXR or FXR Pro is the right esc for the job.
Randy P is offline   Reply With Quote
Old 05-24-2011, 09:21 AM   #6
Well, having already forked out a small fortune on this crawler I'm going to give it a go with the RS since I already have it and it's not being used. If it doesn't work I'll cough up I guess. Thanks for the feedback everyone.
-Aaron
Old 05-24-2011, 11:25 AM   #7
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
The RS will be good, if not overkill. The FXR's are just use because they are cheaper mostly like Eddie said.
Harley is offline   Reply With Quote
Old 05-25-2011, 11:15 PM   #8
I had the same issue running brushed through an RS.
4xFord is offline   Reply With Quote
Old 06-07-2011, 06:02 PM   #9
My RS has been working like a champ. Instant on reverse is working like a charm. Even on old firmware.
