Thread: mamba 25?
Old 02-28-2011, 05:45 PM   #1
Default mamba 25?
i got a mamba 25 on trade works great but what i was wondering if it will run a brushed motor like the sidewinder!
snotrocket is offline   Reply With Quote
Old 02-28-2011, 05:58 PM   #2
Yes, you need to set it for brushed mode, the easiest way is to use a Castle Link, while you are at it upgrade the firmware to take advantage of the crawler settings for the drag brake. I think there is a motor limit of 35T, but one of the electronics guru's here would have a better idea.
jmz6 is offline   Reply With Quote
Old 02-28-2011, 09:24 PM   #3
PapaGriz Yo
Grizzly4x4's Avatar
If the software has been updated to the latest version then yes it will run a brushed motor.
I currently have one in my MRC with the stock motor and it works great.
For a 540 size motor I'd stick with a 55T or slower motor on 2S. Be sure and run an external BEC.
Check out the posts from JRH and EeePee in this thread.
Mamba 25 w/ brushed motor
Grizzly4x4 is offline   Reply With Quote
Old 06-11-2011, 11:37 AM   #4
I just tried my mamba 25 with the newest firmware in my brothers comp crawler with a novak 55T motor and a 1300mah 3S pack and the ESC caught fire and melted after driving about 4 feet.... :( had everything set correctly and we where running a CC BEC for the radio set at 6.0V.
slappomatt is offline   Reply With Quote
Old 06-11-2011, 01:35 PM   #5
What no pictures??
sloppy is offline   Reply With Quote
Old 06-12-2011, 08:19 AM   #6
Sounds like you should have listened to Papa Grizz.
NO 3S!
JC
skid plate is offline   Reply With Quote
