Thread: 7 volts in a 3 cell lipo, how dumb am I?
Old 07-10-2011, 08:13 PM   #1
Default 7 volts in a 3 cell lipo, how dumb am I?
Does that mean I have 2 and a 1/3 volt per cell?
Am I that dumb?
Thanks.
opek is offline   Reply With Quote
Old 07-10-2011, 08:20 PM   #2
TEAM MODERATOR
Reflection's Avatar
Am I that dumb?
Thanks.
Kinda sounds like you have a dead cell.
Reflection is offline   Reply With Quote
Old 07-10-2011, 08:33 PM   #3
Now I go on with the whole nimh dead cell recovery thing? Sounds like fun.
Old 07-10-2011, 08:53 PM   #4
Whoa man, fire up the video camera and have a fire extinguisher ready.
crunky is offline   Reply With Quote
Old 07-10-2011, 09:04 PM   #5
Suck it up!
Duuuuuuuude's Avatar
No. But if you do...
Be sure to get it on film so we can all see it.
Duuuuuuuude is offline   Reply With Quote
Old 07-10-2011, 09:10 PM   #6
The battery only has 1 cycle on it and has been below threshold for under 10 hours. It is currently on a trickle charge, outside on concrete away from anything. I am sitting here on my laptop waiting to swap it onto the good ol thunder power.
As I understand it I have a low chance of some sort of permanent damage which would result in ballooning given the short period of time the battery has been undercharged.
FWIW I do have a fire extinguisher ready
Old 07-10-2011, 09:14 PM   #7
It just started to balloon slightly in one of the cells. Oh well, to the trash with it.
Old 07-10-2011, 09:43 PM   #8
Suck it up!
Be sure to properly discharge it before you do that.
Old 07-10-2011, 09:47 PM   #9
Or film the bin...
Cheers
Dan
Hulksta is offline   Reply With Quote
Old 07-10-2011, 10:47 PM   #10
Light bulb = safe discharge.
Old 07-10-2011, 10:58 PM   #11
Cut the plug off, then tie the + and - wires together and call it good.
J/K DON'T DO THAT!!!!!!
shelby is offline   Reply With Quote
Old 07-11-2011, 01:32 AM   #12
poke it with a stick lol
Rok Krawl is offline   Reply With Quote
Old 07-11-2011, 01:20 PM   #13
I think to properly discharge for disposal you put the battery in a bucket of saline. (salt water) for like 24 hours.
92LILREDYJ is offline   Reply With Quote
Old 07-11-2011, 04:59 PM   #14
Take it behind the shed out back and shoot it, it's how I put down all good things that stopped working.....
speed ghilliesniper is offline   Reply With Quote
Old 07-11-2011, 05:05 PM   #15
Suck it up!
No.
Yes.
Old 07-11-2011, 05:11 PM   #16
just save the other 2 cells make a 2s
vigilant is offline   Reply With Quote
Old 07-11-2011, 07:35 PM   #17
I have read to soak it in salt water from as little as 12 hours to as much as 2 weeks. But I have also read the salt water occasionally causes the contacts to corrode and the battery will remain with an unknown charge (and even worse may read 0 volts while still containing a dangerous charge). A light bulb seems like a fail safe way to discharge the battery safely.
Old 07-11-2011, 07:38 PM   #18
