Thread: help: mongoose esc motor combo error lights
Old 09-06-2011, 09:42 AM   #1
Default help: mongoose esc motor combo error lights
i did a search through the forum and found some info but nothing in detail
I have a mongoos esc motor combo
install it and got the solid red, amber/yellow and blue light
nothing in the mnaual or website regarding the solid 3 lights
I even swap out the motor with another exactly the same novak motor and still the same
even reinsert the sensor wire again and no luck
switch batter too and no luck
using the losi 7.av 600mah 2s2p lipo
reciever is futaba RF614FF
help
thanks
bikeboy is offline   Reply With Quote
Old 09-06-2011, 01:05 PM   #2
I didn't find much beyond this.... http://www.teamnovak.com/tech_info/ts/ts_oneTouch.htm
Did you try to calibrate the ESC to the RX?
--You usually need to have the throttle EPA's set to 100% and the throttle trims to "0".
Is the black or brown wire (from the ESC to the RX) towards the outside edge of the RX when plugged in?
