10-19-2011, 05:58 AM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: Western Australia
| punk dig prob
had my bully on the shelf waiting on parts for a few weeks ,now suddenly my punk dig wont lock the rear when i hit front dig, the dig lights are all working any ideas guys |
10-19-2011, 06:17 AM | #2 |
Is your motor in need of a rebuild? Worn brushes can kill drag brake. Did you try to set it back up, settings may have drifted and while the lights come up correctly, it still isn't quite right. I never ran a Punk Dig, I ran a servo dig on my 2.2 Bully MOA before going to a WantAmix. |
10-19-2011, 07:28 AM | #3 | |
Either way, it sounds like the relay contacts for the relay that controls power to the rear motor have failed. It might be as simple as cracked solder joints to pins around the relay or maybe the relay needs replacing or... maybe something else - hard to tell from way over here, but those are some things you can check. If you want an alternative to the Punk, I make a couple of different versions of dig controller that you can try: MOA Dig Controller for Three Position Channel MOA Dig Controller for Two Position Channel Hope you work things out, Al | |
10-19-2011, 08:03 AM | #4 |
yes the rear is still getting power and making rear turn underpower,i tryed another motor same prob, checked my settings, sounds like the dig,ill pull it out and see what i can find,it was fine till it sat on the shelf for a couple weeks, if i cant fix it think a second fxr maybe the go. cheers
10-19-2011, 12:29 PM | #5 |
Pebble Pounder Join Date: Dec 2006 Location: San Diego
Unsolder the punk from your motors and dunk it in a cup of rubbing alcohol. One of the switches is probably stuck. Mine did the same thing. |
10-19-2011, 06:01 PM | #6 |
Cool will try the rubbing alcohol , is it ok to dunk the whole dig in ?
10-19-2011, 06:42 PM | #7 |
10-20-2011, 05:33 AM | #8 |
Gave the dig a dip in the rubbing alcohol and a little tap to get some of the liquid out,let it dry for 10 mins ,connected everything up and bugger me its working thanx for the help guys happy days.
11-02-2011, 06:18 PM | #9 |
I wanna be Dave Join Date: May 2010 Location: The east coast
just had the same issue with mine. all wheel drive works fine (green light). i can here the relay click in for the front dig (red light) but when i switch to rear dig (blue light) there is no relay click. probably did it to myself. the case on one of the relays broke off and i superglued it back in place. i'm curious if any glue bled down into the relay. not the smartest move on my part! going to give the alcohol dip a try. any recommendation on how long it should be in the bath? |
11-05-2011, 05:29 AM | #10 |
I just gave the unit a dip and wash in a glass for a few secs then huffed and puffed to get all the solution off ,let dry for 10mins gave the relay boxs a tap with a spoon and all was working again,good luck.
11-05-2011, 09:29 AM | #11 |
gave the alcohol bath a shot. no joy. oh well, it does give me dig in one direction. maybe i'll find a use for that somewhere.
11-06-2011, 01:51 AM | #12 |
you must have got some glue in the relay,maybe worth removing the plastic case and trying again,nothing to loose now,you maybe able to see something with the case off ,not sure whats inside..
11-06-2011, 04:39 AM | #13 |
| as much as i want to break it open and see what's inside i might just leave it as is. i'm planning on another moa project (bully axles) so my son can have a basher. might be worth keeping as is so it has at least front dig. definitely won't be able to use on my comp rig!
