12-28-2011, 03:19 PM | #1 |
Rock Crawler Join Date: Nov 2008 Location: missoula
| cc 10 amp bec how do i program
i have the cable what voltage do i set it at for dual steering on my timbuck 2. its preset 5.1 i think, i have a 5 novack now just need help thanks guys im having low end issues when i punch it it glitches but if i roll the throtlle its fine was told this was the fix.
12-28-2011, 05:20 PM | #2 |
| Re: cc 10 amp bec how do i program
set it to whatever your servos are rated to. likely you will want to set it at 6v or maybe a hair more like 6.2 or so to get a lil extra power from them
12-28-2011, 05:22 PM | #3 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
| Re: cc 10 amp bec how do i program |
12-28-2011, 05:43 PM | #4 |
Rock Crawler Join Date: Jan 2009 Location: Christchurch, New Zealand
Actually there are two things to consider when setting your BEC voltage. 1. The max voltage of your servo's (as mentioned by others) 2. The max voltage of your receiver. As long as 1. is NOT higher than 2. then you will be fine setting it for your servos. This also depends on how you are wiring in your BEC, either direct to servo's, or through the receiver. Obviously, if direct to servos then point 2. above is not relevant. Cheers, Mike. |
12-28-2011, 06:41 PM | #5 |
thanks guys 6 volt is where the servo is max thankyou
cc 10 amp bec how do i program - Similar Threads | ||||
KCRC/KOH race program & classes ?? | the DMG | Missouri | 75 | 04-18-2011 01:14 PM |
how do I program my cc bec | James003 | Electronics | 6 | 01-10-2010 10:28 PM |
What to use to program the CC BEC? | CreamLad | Electronics | 9 | 05-02-2008 09:35 AM |
cc bec program help!! | mudboger07 | Electronics | 22 | 03-15-2008 10:23 AM |
