12-28-2011, 11:51 PM | #1 |
Newbie Join Date: Dec 2011 Location: Canada
| Novak rooster crawler settings
Hey I have been wondering if my esc is in lipo cutoff mode cause whenever there is pressure on the wheels power drastically decreases and I can't make it up anything how would I Know that it is in lipo cutoff and if it is how do I take it out of that mode and back into nimh mode. Haven't seen much about this on any forums thought I'd bring it up any help is nice
12-29-2011, 12:50 AM | #2 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: Novak rooster crawler settings
here you go. dont forget to disconnect esc from receiver |
12-29-2011, 08:09 AM | #3 |
Pebble Pounder Join Date: Aug 2011 Location: Geneva, MN
The lipo cutoff on the esc will cut power for a second every like 5 seconds so its stop and go. You might have other issues.
12-29-2011, 09:52 AM | #4 | |
Quarry Creeper Join Date: Mar 2006 Location: SoCal
Charlie, csuangka@teamnovak.com, is Novak's Crawler expert and will be happy to answer your questions. Quote:
12-29-2011, 09:55 AM | #5 |
Thanks I did have lipo mode on but I was told that a 45 then motor is no good for. Truck with with worn drive so im gonna try a different motor see what happens thanks for your help!
12-29-2011, 11:22 AM | #6 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
i got the same esc and switch between nimh and lipo often.. here's how i do it.. with the all power off. plug in a battery, turn esc on, press button briefly the light will flash once. press and hold the button and if you see 1 flash your in nimh mode, if you see 2 flashes then your in lipo mode. if your in lipo cutoff mode when your driving along it will start "shutter" and wont move. if you running nimh than you'll want to go through this procedure. |
12-29-2011, 11:32 AM | #7 |
Thanks alot!! Problem solved !
12-31-2011, 08:36 PM | #8 |
RCC Addict Join Date: May 2010 Location: Midwest
Cool.. I just needed to do this and couldnt find my instructions. Search Button |
Novak rooster crawler settings - Similar Threads | ||||
Tekin Rebel 2/novak Rooster Crawler/novak Super Rooster? | CHRIZAD | Electronics | 7 | 09-15-2008 07:22 PM |
novak rooster crawler | skate | Electronics | 8 | 02-19-2008 08:52 PM |
momba max vs. novak goat vs. novak rooster crawler | punkafi888 | Electronics | 4 | 01-20-2008 02:05 AM |
Novak Rooster Crawler | Jusstinno | HPI Wheely King | 4 | 11-24-2007 11:06 AM |
Novak Rooster Crawler Edition ESC -- The Crawler Store | EeePee | Vendors Market | 20 | 07-30-2007 09:19 PM |
