12-30-2011, 07:44 PM | #1 |
Newbie Join Date: Dec 2011 Location: post falls
| novak goat 3s
i got the novak goat 3s 18.5 crawler combo for my lcc installed it was running perfict then yesterday it started to have a delay going from forward to reverse but no delay from reverse to forward i rebound my radio reset the esc programing to make sure it was on worm drive and reset my radio end points for the esc and it still has the delay any one else have this issue or know what it might be
12-30-2011, 07:46 PM | #2 |
| Re: novak goat 3s
Sounds like the ESC is not set to "instant reverse"..... |
12-30-2011, 07:57 PM | #3 |
| Re: novak goat 3s
is there a setting for that i just figured it would be all in the worm drive profile
12-31-2011, 12:27 AM | #4 |
| Re: novak goat 3s
I have looked at all the set up sheets and don't see any other set up for worm gears ... The lights on the esc are solid red in neutral solid green at full throttle like they should be but when I go right to reverse there is a flashing green light but going from reverse to forward there is no delay and no flashing green light
12-31-2011, 05:50 AM | #5 |
| Re: Novak goat 3s
Novak can be such a PITA to find manuals....... I found this page..... Goat 3S Crawler Brushless/Brush ESC that has a link to a manual. I agree, I do not see anything relating to a reverse. A lot of other ESC's allow you to set: -No reverse -Double tap reverse -Instant reverse I see no reference to these in your ESC. Maybe someone will chime in. What radio are you running? |
12-31-2011, 06:29 AM | #6 |
Rock Stacker Join Date: Jan 2010 Location: Binghamton
| Re: novak goat 3s
I've got the same setup. my understanding of the system is that the instant reverse will only work with novak crawler specific motors and the only way the esc knows it is hooked up to a crawler motor is the sensor cable. Make sure the cable is intact and fully seated at both ends. maybe try a different sensor cable. |
12-31-2011, 09:55 AM | #7 |
RCC Addict Join Date: Aug 2009 Location: Earth?
| Re: novak goat 3s
If it is a 18.5 Ballistic motor than you need one of these Novak Electronics - Ballistic Crawler Timing/Sensor Assembly? The Novak crawler motors have a built-in resistor that is connected to the blue wire on the sensor cable. The resistor is how the ESC knows the motor is a crawler motor. Your resistor is blown. If you dont have the Ballistic motor you can solder a resistor into the blue wire or send the motor back to Novak if its under warranty and they will send you a used/rebuilt motor. There warranty will not give you a new motor even if you bought it new and took it right out of the box. |
12-31-2011, 09:55 AM | #8 |
| Re: novak goat 3s
I'm running the specktrum dx3e
12-31-2011, 10:02 AM | #9 |
| Re: novak goat 3s |
12-31-2011, 10:08 AM | #10 | |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Re: novak goat 3s Quote:
12-31-2011, 10:19 AM | #11 |
| Re: novak goat 3s
If that resister was bad would it have a delay going from reverse to forward
12-31-2011, 10:32 AM | #12 | |
Dont think so. Never heard of anyone having a delay going from reverse to forward unless you have the channel setting reversed on your radio or motor wired backwards. | |
12-31-2011, 11:07 AM | #13 |
| Re: novak goat 3s
OK. Anyone out there mod a motor to work with a goat esc? I'd like to know if it worked and what size resistor they used.
12-31-2011, 11:31 AM | #14 |
| Re: novak goat 3s
I just reversed the motor rotation so now the delay is going reverse to forward witch is better than forward to reverse for now until I change that resister
12-31-2011, 11:44 AM | #15 |
| Re: novak goat 3s When you change the resistor would you mind taking a couple pics along the way? Would like to see how it compares to my tekin.
12-31-2011, 12:07 PM | #16 |
| Re: novak goat 3s
I can do that
10-17-2012, 05:30 PM | #17 |
Newbie Join Date: Oct 2012 Location: Blacksburg
| Re: novak goat 3s
Did anybody ever figure this issue out or solder in the resistor to fix it? I have a LNC with a goat 3s running a 21.5t losi xcelorin and have the same issue. It makes crawling and climbing difficult/obnoxious when you can't quickly grab reverse. I get the same blinking green LED when I try to quickly reverse from forward.
novak goat 3s - Similar Threads | ||||
Novak Goat Vs Novak Goat Ballistic?? | k_r_a_c_k_e_r | Electronics | 3 | 02-19-2010 07:53 PM |
Novak GOAT ESC only works with Novak BL-Motors? True? | spiderschwein | Electronics | 6 | 09-01-2008 04:11 PM |
momba max vs. novak goat vs. novak rooster crawler | punkafi888 | Electronics | 4 | 01-20-2008 02:05 AM |
