01-03-2012, 02:55 AM | #1 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
| Firmware update on FXR?
So, i bought a used FXR Pro and it has been working 100%. It was already set up when I got it. Now I bought the hotwire to set it up myself. I wanted to set up the custom lipo cut-off so I could get rid of the buzzer. Being a cautious guy, I didn't trust the lipo cutoff that hasn't been set by me. When I connected the FXR to the computer I set the custom cut-off to 10.5 or something like that, just to test it, and left the other setings as they were. When I went to try it out the esc would no work at all! Not even the sound when the esc is turned on. I thought that it was a gonner and I was another guy with a fried FXR... I pluged it back to the laptop and went from the custom cutt-off to the 3s, as it was before, and it is working 100% again! My question is: The FXR firmware is the 028. Will I risk it and update the firmware to see if I can setup the custom cutt-off with the new firmware (the 029 or 030?), or wound I be risking frying a working ESC? Being a relative newcomer to this I would really apreciate your input... |
01-03-2012, 03:12 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
| Re: Firmware update on FXR?
Always flash to the new firmware. There's a reason they go through the trouble of updating it ^_^
01-03-2012, 10:06 AM | #3 |
I agree. I cant remember what firmware it was but a couple versions ago there were nasty startup issues that have now been resolved, worth the update for sure. I believe you are paranoid because of the issues with the NovakLink and the M2 ESC...That is a different brand and I have updated both of my FXR's and have not had a problem with either one of them. Also 10.5 is rather high, cant say why it doesnt work as it should work. I run mine on the safe side and run 3.2-3.3v per cell, I am assuming by your numbers that you are running a 3s pack so try 9.6-9.9v on the cutoff. Who knows why 10.5 doesnt work right, maybe your pack was drained when you hooked it up. Last edited by SMR 510RR; 01-03-2012 at 10:08 AM. |
01-05-2012, 05:05 PM | #4 |
Firmware updated and cutt-off is at 9.9v. Everything is working! Thanks for the help! |
01-05-2012, 05:16 PM | #5 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| Re: Firmware update on FXR? |
01-08-2012, 08:13 AM | #6 |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
I've heard of weird problems like that with v028. I would definitely update to v030 and it will probably remedy the problem. Sent from my Star Trek communicator from the bowels of outer space ;) |
Firmware update on FXR? - Similar Threads | ||||
Castle Firmware | skid plate | Electronics | 2 | 01-11-2011 10:23 AM |
Update your FXR via Vegas 208 Hotwire | Rig Rocker | Electronics | 11 | 10-06-2010 04:21 PM |
Glitching with New Castle Firmware | EXW | Electronics | 16 | 01-24-2010 07:56 AM |
FXR update issue | crash | Electronics | 2 | 08-31-2009 11:06 AM |
